Tein STech, need camber bolts?
My Tein S.Tech springs will arrive today or tomorrow, along with a used Courtesy Nissan FSTB.
Will I need camber bolts in order to avoid too much negative camber?
If so, will it be bad enough that I shouldn't install the springs until I have the bolts in hand?
I know this is probably frequently asked, but it doesn't appear to be in the FAQ and search isn't available...
Thanks!
-Jacob
Thanks!
-Jacob
$86 for some bolts?
http://www.ptuning.com/html/Item-Des...delDesc=Maxima
$86 for a set of bolts... that seems kind of high, no? Does anyone have any rec's or thoughts on pricing and where to buy?
Thanks!
-Jacob
Thanks!
-Jacob
I bought the Eibach camber bolts and didn't need them. I took the car to NTB with the bolts for my aligmnent, I got my camber bolts back without them being installed and my camber is -0.5 degrees. So you're all set with not getting camber bolts. I was suprised I didn't need them.
Originally posted by studman
According to TEIN, you do not need the camber bolts. I can't confirm this yet, because my springs haven't arrived.
btw I found an auction on EBay for some Sprint camber bolts for like $50...
Originally posted by Triple8Sol
Really? Where did you hear this?
Cool, thanks for the input. How about bump stops? Did you guys trim them down as recommended then?
but do trim them, it wont really cause any serious problems. It just helps absorbe the last bit of impact incase you bottom out. I would still say trim them but you wont notice any differance.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
