Tein STech, need camber bolts?
My Tein S.Tech springs will arrive today or tomorrow, along with a used Courtesy Nissan FSTB.
Will I need camber bolts in order to avoid too much negative camber?
If so, will it be bad enough that I shouldn't install the springs until I have the bolts in hand?
I know this is probably frequently asked, but it doesn't appear to be in the FAQ and search isn't available...
Thanks!
-Jacob
Thanks!
-Jacob
$86 for some bolts?
http://www.ptuning.com/html/Item-Des...delDesc=Maxima
$86 for a set of bolts... that seems kind of high, no? Does anyone have any rec's or thoughts on pricing and where to buy?
Thanks!
-Jacob
Thanks!
-Jacob
I bought the Eibach camber bolts and didn't need them. I took the car to NTB with the bolts for my aligmnent, I got my camber bolts back without them being installed and my camber is -0.5 degrees. So you're all set with not getting camber bolts. I was suprised I didn't need them.
Originally posted by studman
According to TEIN, you do not need the camber bolts. I can't confirm this yet, because my springs haven't arrived.
btw I found an auction on EBay for some Sprint camber bolts for like $50...
Originally posted by Triple8Sol
Really? Where did you hear this?
Cool, thanks for the input. How about bump stops? Did you guys trim them down as recommended then?
litch
123
01-04-2024 08:01 PM
knight_yyz
11-01-2015 02:34 PM
RealityCheck
10-02-2015 07:34 PM
