How can I find more power for the Max?
1997 Nissan Maxima SE 5 Speed
I have installed:
1. Y Pipe
2. B Pipe
3. Aftermarket Muffler
4. JWT Intake
Excluding the supercharger or turbo what else is left ? How can I find more power, and make the 97 a bit faster ? At this point do you start shedding weight ?
I have installed:
1. Y Pipe
2. B Pipe
4. JWT Intake
Re: How can I find more power for the Max?
I have installed:
1. Y Pipe
2. B Pipe
4. JWT Intake
I have installed:
1. Y Pipe
2. B Pipe
4. JWT Intake
there is a list of things
Originally posted by optimus310
pulley, flywheel and might as well do the clucth if you get an ultra light flywheel, Upgraded ECU, NOS, injectors, turbo or SC, Maxima.org sticker, Ignition Amplifier.
Re: there is a list of things
Will the custom maxima racing pipe also give gains over stock cat converter or is this a myth ? i did not see that on the list .not that im going to put it on my car and destroy the environment but is it also able to increase 1-2 HP ?
Originally posted by FLAVOR247
Ignition amplifier? Who makes that? And do maximas benifit from it being that each plug has its own coil?
Originally posted by 4thgenguy
What kind of gains will get from clutch/flywheel combo. Which flywheel would be the best for 0-60 gains and still be comfortable as a daily driver?
But it's true
Do you want to stay N/A? If so...
Underdrive pulley
JWT ECU
MEVI
High flow cat (only good for like 2 HP if that)
Thats all i can really think of for power mods, there really are not that many N/A mods. BTW i really dont think the straight pipe will give you that much of a HP gain. Maybe a little but better than a high flow cat. But still not really worth it since you kill the environment and will need to take itoff for emmsions testing. Plus the fines for having one are huge!
Underdrive pulley
JWT ECU
MEVI
If you want big power and fast, get nitrous.
I have installed:
1. Y Pipe
2. B Pipe
4. JWT Intake
I have installed:
1. Y Pipe
2. B Pipe
4. JWT Intake
main mods
1. as for as the ECU, what are the options for people who one a 97 model ? Do we look for the 96 and does it work ? Also what does the ecu do to make the car faster, is it worth the money ... at this point is an upgraded ecu one of the best things that are left ?
Originally posted by mrmaxima97
Just don't plan on running a lot off of it, like amps, ps2, lcds.
IMO
to get the best performance, make sure your car is in tune.
i cleaned my TB and replaced plugs and my car was flying afterwards. Best performance is keeping your car tuned.
Originally posted by Magikone69
IMO
IMO
Also I have had the JWT Popcharger on for a long time and it has never beened cleaned... thanks for the post..
This is true... im in need of a tune up as well. does the dearlerships check and do everything necessary or do you have to specify extra things you want done. example cleaning throttle body ?
a lil note my friend baught some NGK platinum plugs 3 years ago when changing his old ones, he went to a local mechanic to have them installed. We just changed his plugs lately and guess what we found ... some CHAMPIONS. the mechanic took his 60 dollar plugs and swapped them with 10 dollar ones we did not know until now. We went to the shop but he doesnt work there and the owner said its been to long there is nothing he can do.
I just posted this as a suggestion to anyone, when you bring in something to get installed make sure they do it right.
tsi6001
Oct 3, 2022 10:23 PM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
