Brighter corner light nub higher or lower.
Folks, use your heads. What you want to do is access the other filament on the bulb. The easiest way that I have found to make the bulb brighter is simply to make sure there are two nubs (making for contact of the 27Watt side of bulb). In my '98 Max, I added a "Nub" where there was a space for one (I did not already have one there). I soldered some speaker wire to the existing nub and shoved it down the hold, making a small "Nub" out of the wire and some solder. That way, you don't cut anything, and if you want to undo it, simply take out the nub you made. On the older models, there may be slight differences, but just experiment and do some thinking instead of letting others do all of the thinking for you. How do you think THEY figured it out?
Hey i have read earlier that this requires a fuse change. I had also read a while back that by making the corner lights brigher some people where having some werid electrical problem...has anyone experienced this?
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
