Can't get an ignition coil out
Old May 1, 2003 | 08:34 PM
TLM's Avatar
TLM
One of the bolts holding it in is dulled and I can't use my socket wrench. It just spins and can't hold onto anything..
Any ideas how to get it off?
Old May 1, 2003 | 10:24 PM
«§»Craig B«§»'s Avatar
make sure you're using the correct size - 10 mm
try using a large phillips head screwdriver - #3 size
use vice grips on the bolt head and uncrew it, it shouldn't be in there that tight
I know craftsman makes some tools to help hold on to rounded bolts if the other things dont work
Old May 2, 2003 | 12:03 PM
unocivil's Avatar
Re: Can't get an ignition coil out
try using needle-nose vice grips. If that doesn't work, cut straight slot for standard screwdriver into top of bolt. A cutting disk works best for that.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
