Nyc Inspection Failed !!!!
ALRIGHT I NEED SOME HELP HERE I HAVE A 96 I30T YPIPE N CAT BACK AND STILLEN INTAKE
SO I GO FOR INSPECTION DRIVE A GOOD HOUR BEFORE I DROP THE CAR OFF THEY DO THERE TEST THING I COME BACK AND I FAIL FOR NOx the limit WAS 1.50GPM I TESTED 2.05 GPM THE REST OF THE READINGS ARE AS FOLLOWS HC .26GPM AND CO 5.80 GPM I
IF ANYONE COULD LEAD ME A DIRECTION TO FIX THE PROBLEM I WOULD APRECIATE IT
ALSO JUST GOT AN INJECTOR CLEANING 2DAYS AGO AND NEW PLUGS
Re: Nyc Inspection Failed !!!!
cats start to work only after they get to a certain temperature..
or an effective solution: you can put your stock y-pipe back on for inspection and then pass, and then put the aftermarket y-pipe right after, successfully fooling the system. it's a bit of work but it beats paying $35 for each failed inspection.
-Vadim
Clean your throttle body if it wasn't included in your injector cleaning.
See www.motorvate.ca for instructions.
Use the higher octane gas if you aren't using it now.
DC_Juggernaut
Sep 28, 2015 04:07 PM
DayHeyZeus
Sep 11, 2015 03:17 PM
