I'm close to finishing the install, have a few questions Please help!!
Old May 10, 2003 | 04:31 PM
joaquink's Avatar
¿Hablas Español?
Well, you put that there and then this goes here. Don't forget the whatchamacallit that connects to the hoodad (a common mistake). Some people don't post very clear questions so when I see one as direct as yours I'm happy to help.
Old May 10, 2003 | 08:01 PM
CASS98SE's Avatar
I dont know what happened to my first post? OKay my questions are as follows... I am using a GReddy Bov. What am I supposed to do with the hose that runs from the bosch to the airfilter?? What do I do about the hole on the airfilter? How do you fit the air intake sensor in the supercharger pipe if you have a "newer car". How did you get the M.A.S. connector to reach after the pipe is in?
Old May 10, 2003 | 08:32 PM
JAY25's Avatar
Plug both holes that are on the KN filter take the filter to Pep boys and they sell these large rubber caps and they just slide on and zip tie it and your done. attach a small filter on the side of the valve cover breather and dont attachit to the pancake filter it will suck oil into the blower and into your intake you dont want that. run your bov hose to this bottom piece by using a plastic T adapter like this
exactly the way you see it on this picture this is the location
http://www.vanillaice.com/webmasters...e/IMG_0302.jpg
Old May 10, 2003 | 08:33 PM
JAY25's Avatar
see the hose on the bottom of this picture attach a small filter to it and your done
http://www.vanillaice.com/webmasters...hmosh/VI13.jpg
Old May 10, 2003 | 10:06 PM
CASS98SE's Avatar
Old May 11, 2003 | 06:00 AM
JAY25's Avatar
your replacing the bosch hose with the BOV, I just told you to put a cap on the K&N filter. with the sensor if it dont fit you make it fit, the kit comes with two screws try to use the gaskets it came with and this small plate and screw onto the elbow.
The MAS cable is too short grab a razor and cut into the tape very carefully and stretch until you have enough cable to reach the MAS
hope that ans your question
SmokinMax02
18
Sep 11, 2015 12:25 AM
JoshG
21
Sep 4, 2015 09:04 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Team STILLEN
Aug 10, 2015 04:29 PM
