High miles with MEVI good?
Don't know of any reason the VI would matter on a high mileage car. It is in noway dangerous to the engine. Heck, these came stock on some Max's over seas, so Nissan sure did not think it would matter.
I have over 100K miles with a VI, others have a VI with many more than that.
I think it would better for the engine cause it allows the right amount of air into the engine at all times and probably puts less strain on the engine...
all it is doing is freeing up HP effeciantly
-matt
-matt
High mileage shouldn't really affect anything since the VI just improves airflow at high rpms. The only adverse effect I can think of might be extra metals in your oil. The reason I say this is after installing my VI and having my oil analyzed the wear metals were higher than normal. I told the analysis reviewer (Terry Dyson) that I had installed a VI, so he said that's likely where the metals came from.
-hype
-hype
Originally posted by dwapenyi
Huh?
the VI is slowly dissolving? Or, could it simply be that the VI makes you stay in the upper RPMS longer, therefore your engine wear will be more significant?
DW
Huh?
the VI is slowly dissolving? Or, could it simply be that the VI makes you stay in the upper RPMS longer, therefore your engine wear will be more significant?DW
Excerpt...
"Also worth noting is my new intake manifold at 54k. The manifold was brand new, and I was able to clean my lower intake manifold as well."
Terry's response: ANOTHER SOURCE OF SOFT METALS AND SILICON.
-hype
CorollaULEV
30
Aug 9, 2021 08:11 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
y pipe on order
