Defi fuel pressure gauge installed! 100+psi @ WOT
Old May 20, 2003 | 12:12 AM
[maxi-overdose]'s Avatar
Hi all:
I finally install this gauge...now I have four gauges. next gauge will be either oil temp or pressure, pretty soon my car will be like F-16 cokpit.
I picked this gauge because it's the only one in psi unit that I can find beside autometer. I paid 175 for it thru e-bay and waited a month for it to come... It has a plastic ring with an arrow on it so you can move it around and mark any reading you want (I found this not so useful though....)
pictures:
my thoughts:
the install was pretty easy....I tapped the sensor right after the aux fuel pump....I put the gauge in my center gauge pod and I think it is a bad idea....I should've put it near the boost gauge so I can look at both of them with one glance.
it is pretty accurate. my idle FP is 39psi and I took her to 6 psi of boost. the FP turned 70psi and I have a 8:1 disc. (6*8 + 39/2) @ WOT I have seen FP reach above 100psi. I didnt check how much boost I was running.....I only took a glance at he FP gauge.
Old May 20, 2003 | 12:14 AM
with the plastic gauge ring
and thanks to those who helped me out on this install....confused , turbo95max, Kevin, wizzamax...
I didnt hook up the 12v battery wire and it still works
Old May 20, 2003 | 04:12 AM
Confused's Avatar
Permanent Maxima.org Resident
congrats...
didn't know why you had the constant 12v either with no memory functions
Old May 20, 2003 | 07:09 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
100+ psi?
Old May 20, 2003 | 07:46 AM
Originally posted by Confused
congrats...
confused: I took a look at the instruction again....turned out all the defi electronic gauges use the same power cable. Probably it is required for gauges that have memory feature....
Originally posted by Y2KevSE
100+ psi?
maybe I should go straight to 6:1 FMU for now
Old May 20, 2003 | 08:06 AM
WizzaMax's Avatar
wow...that is hi pressure...
Old May 20, 2003 | 11:56 AM
hmmmm...I wonder how high is high....I dunno if my injectors are able to handle this much pressure.
Finkle
Sep 27, 2015 09:53 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
305head
Aug 26, 2015 09:03 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
