Level 10 Manual shifter Unit Update
Old Jan 24, 2001 | 06:58 PM
i30krab's Avatar
I received a new set-up from Pat at level 10 the other day.
I am testing this prototype.
It consists of a controller box with 4 buttons for 1st thru 4th gear, a computer fooler box to keep the check engine light from coming on,this mounts under the hood, a torque converter lock-up box, and a box that allows you to change the shift pressure. You can switch from auto to manual on the fly. Manual shifting is great off the line. The combination of turning up the valve body pressure for quicker slam shifts and winding thru the gears to redline is awesome! This is much faster than letting your tranny shift itself. For routine driving you put the switch back to auto but you still have control over the valve body pressure. You can downshift this unit. There are still problems, The check engine lite still goes on after a while but pat says it's an easy fix. Also the valve body switching needs some refinement.
Pat is also workink on a new controller that will mount on the shifter and will work like the mercedes unit where you flip a botton to upshift and then slide it to down shift.
I really enjoy driving with this unit. The car really jumps off the line like a stick. I am guessing the unit will sell between 900 to 1200 dollars.
Old Jan 24, 2001 | 08:36 PM
Confused's Avatar
Permanent Maxima.org Resident
and a visual of the current shifter
How's the KRAB?
[Edited by Confused on 01-24-2001 at 10:38 PM]
Old Jan 26, 2001 | 10:21 PM
maximaisokay's Avatar
where can i put a coffee cup?
i always drink coffee.
more creams please.
John
Old Jan 27, 2001 | 01:33 AM
mingo's Avatar
i really hope they would do more refining on the looks of the unit tho..
Old Jan 27, 2001 | 08:29 AM
i30krab's Avatar
Re refinement
I appreciate your imput but if you reread my post it says prototype. The post also says the unit will eventually mount on the shifter.
No disrespect meant , but a lot of you people do not read the posts carefully !!
Old Jan 27, 2001 | 10:13 AM
SteveChicagoSC's Avatar
Cool mods!!!! Thanks for the udate!!!!!n/m
n/m
Old Jan 27, 2001 | 10:20 AM
bullseye's Avatar
Re: Re refinement
Read? I just come here to look at all the pretty pictures! J/K..... :-)
Old Jan 27, 2001 | 12:15 PM
1997 Maxima SE's Avatar
kinda dumb but do you shift with the buttons?? or is that the buttons to controle pressure... looks like a cool mod, how about some track times...
Old Jan 27, 2001 | 01:42 PM
mingo's Avatar
Re: Re refinement
i was aware that it was a prototype, that's why i said looks need more refinement.. instead of.. it would be cool if it looked better. sorry for not throwing out that line. i don't mean to disrespect at all.
anyways, keep us posted on how it all goes i'm suprised that there is actually someone researching sucha cool mod for our cars.
user 11122324
42
Jul 18, 2022 03:35 PM
Fbana41
Aug 29, 2016 12:18 PM
Need help
23
Oct 2, 2015 08:56 AM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
