Bad idle with new fuel pump
Anybody had any problems when they put in the walbro 255lph with idle...my car dont' wanna idle good, infact it don't idle it dies. Stays around 1k.
And then theres this other thing happning that happend when the pressure pipe blow off on the dyno where now it seems to stall and die out when you touch the gas.
Ideas?
Another note, how many quarts of oil does the max now take with the s/c?
on a side note i'm ready to rip out most of the performance crap intercooler 2.87 and all. Maybe an m3 or m5 could replace it, but first I wanna try and get this ****ing thing running for once.
Ideas?
Originally posted by max'n out
Also, the fuel pressure is at about 40psi at 1k. And no it's not low on gas.
It's around 40psi
Stays right around it. But it's idling at 1k rpms it will not ever drop below that...then the car dies when you tap the gas. Anyway it's going to the shop 2 morro, ive been working on ideas over the past two weeks, thought I'd post it see if anybody had any insight.
Re: Bad idle with new fuel pump
Ideas?
Ideas?
The Walbro pump isn't the cause of the problem. I installed the 255 lph pump in my car several weeks before installing the SC. Yes, fuel pressure was up around 40 psi at idle (still is), but it has never had any idling problems since installing the pump. I think your problem is related to whenever the pressure pipe blew off. Maybe you blew the MAF sensor at the same time. Or it created a vacuum leak somewhere.
The SC and oil line don't hold much oil, so the oil capacity is about the same as before. Check your dipstick, if it looks low, add oil.
Re: Re: Bad idle with new fuel pump
I could figure out how to pull the dip stick and check
Re: Re: Re: Bad idle with new fuel pump
My question about the oil was not really related to anything else...I'm doing the oil change and need to know how much of redline to get, I don' know what I did with the book so I dont' know how much it holds.
