How accurate is the outside temperature gauge...
Old May 29, 2003 | 07:34 PM
Max Version 3.5's Avatar
and where is it located on 02-03 Maximas?
Old May 29, 2003 | 07:54 PM
THEKNITE's Avatar
Re: How accurate is the outside temperature gauge...
Mine seems to be pretty accurate, and it is located at "idontknow".
Old May 29, 2003 | 07:55 PM
bluemaxx's Avatar
Moderator GT-R
Mine seems very close to reality if the care is moving, will go way high if sitting in traffic, hot pavement.
Old May 29, 2003 | 11:01 PM
96_vqmax's Avatar
It's located in the digital displace at the bottom of the rpm tach.You might need to use the mode button on the steering wheel to select it.
Old May 29, 2003 | 11:04 PM
ABS's Avatar
ABS
I believe the sensor is located under the hood in front of the radiator. It is extremely accurate (within 2-3 degrees) in most cases. When the car has been sitting or is running and sits for a while, it may be off at first until it cools off from wind blowing by it.
Old May 29, 2003 | 11:30 PM
96_vqmax's Avatar
Oh,my bad.I though he was asking about the reading.
Old May 29, 2003 | 11:37 PM
mclee45's Avatar
i thought it was located on the front part of hte dash by the windshield.
Old May 30, 2003 | 04:59 AM
PCGuRu2K's Avatar
It's the sensor on the hood scoop
Old May 30, 2003 | 05:36 AM
DAP's Avatar
DAP
The sensor is fairly accurate as long as the car isn't sitting for a long period. Usually off a degree. I'm a weather observer at the airport and the temp sensors we use are official data and I've compared it to the car when I arrive at work and leave.
Old May 30, 2003 | 06:58 AM
t56gen3's Avatar
I glanced the other day and noticed what looked to be it in front of the radiator. I saw it through the lower grille. Pretty close to the ground. Hot pavement makes it read high (in my case.) Pretty accurate at night.
Old May 30, 2003 | 07:21 AM
naerok's Avatar
I wish i had this function....
Old May 30, 2003 | 08:04 AM
optimus1's Avatar
temp sensor
that's the interior temp sensor, and on the other side of the dash is the lite sensor.
Old May 30, 2003 | 08:09 AM
Hazard66V6's Avatar
how much would it cost to swap this feature into a 2k?? would it be possible?
Old May 30, 2003 | 11:26 AM
MONTE 01&97 SE's Avatar
same here, and my tech told m its what you said its the hot ground or even heat from the motor to cause it to be off when its hot out.
Old May 30, 2003 | 11:29 AM
It coms as a part of the trip computers in the 02/03's and you would have to change your gauge cluster and intstall all of the wiring and sensors to a pre 02 which is expensive. In the 00/01 it was a part of the automatic climate control which again would be expensive and alot of work. Just buy a portable unit.
Old May 30, 2003 | 02:07 PM
t56gen3's Avatar
Yeah, it's hot. I think this is a degree or so off. Weather channel says it's 100, soooo......
Old May 30, 2003 | 04:27 PM
Where in DFW are you Coppell area here?
Old May 30, 2003 | 06:03 PM
caremd99's Avatar
The temperature gauge is much more accurate than the MPG function!
Old May 30, 2003 | 06:27 PM
t56gen3's Avatar
Plano/McKinney area. You should come to the DNE meet tomorrow. We would like to see more 5th gens (the 4th gens outnumber us at the moment!)
Sat 5/31 Meet @ Tigerbulls
Old May 30, 2003 | 11:21 PM
CO2kmax
That was halarious, mabey im just in a laughing mood but that was good. I must have not had that option on my car. Think I should put a new wrx scoop on my max?
doctorpullit
Oct 28, 2019 10:58 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
Smackasmith
Feb 1, 2016 12:40 AM
msellas
Sep 23, 2015 09:16 PM
RWCreative
Sep 21, 2015 11:01 AM
