Y pipe or exhaust first
Get the Y-pipe first, but why not just get a Budget Y-pipe for $180 shipped instead of the Cattman pipe? They are both quality made and will give you the same HP gains. And the cheapest price i have seen for the Greddy SP catback is $485 at www.adventon.com
Originally posted by SleepyMaxxx68
The best bang for the buck......
tia
icheban26(newbie)
the y-pipe is part of the exhaust system. It has two inlets that meet at a "Y" connection and form one outlet pipe that connects to the catalytic convert. The furthest reaching inlet connects to the front bank of cylinder's exhaust manifold and removes exhaust. The middle inlet (closer to the outlet of pipe) connects to the rear exhaust manifold and removes exhaust from there. An aftermarket y-pipe is a straighter tube than the stock pipe and doesn't have pre-catalytic converts.
Originally posted by icheban26
newbie question....wat exactly is a Ypipe???
tia.
tia.
http://www.budgetexhaust.com
check out their 'custom parts' to see the Y (they call it an F pipe though) and keep in mind all prices are in canadian dollars.
For all the questions about y-pipes, exhausts, everything airflow:
http://drewm.dyndns.org/~drew/maxfaq...imaPerformance
now i know. thanks bb0ys, SleepyMaxxx68, LiquidNine for educating a newbie. i will def look more into changin my Y/F pipe as soon as i get my suspension replaced.
thanks
icheban26
thanks
icheban26
The pics and text are great. There are dyno plots showing the difference in performance between oem y-pipe and aftermarket pipe (Budget Exhaust's in this case).
Originally posted by pjalst
How many O2 sensors attatch to the Y pipe, and what is it called( i want to replace mine when I install a Y pipe
There are 2 O2 sensors in the non-cali spec Ypipe (unsure about the cali cars)... if you crawl under your car you will see them screwed in perpendicular to the vertical section, one for each down-pipe.
