Is it ok to start engine w/o anything connect to throttle body?
I currently don't have anything connected to my throttle body. What I mean by this is that my MAF, airbox, filter, and any other pipe and air scoope is not connected. So there isn't anything connected on the right side of my throttle body. Is it safe to start my engine without anything connected to the throttle body? Will it cause any damage to my vehicle. All I want to do is release my fuel pressure so that I can replace my fuel filter. So it just needs to be on for like 5 sec and then turned off and turned on again maybe 2 more times for 5 sec each until my car stalls.
Re: Is it ok to start engine w/o anything connect to throttle body?
You can also remove the fuse next to the steering column for the feul pump and start the car untill it stalls, that should release pressure so you can install the feul filter
http://www.maximadriver.com/modules....=article&sid=8
vingodine
45
May 21, 2016 12:46 PM
homewrecker
Aug 24, 2015 08:56 PM
maxinout93
Aug 20, 2015 02:17 AM
