96 Maxima BRA, just got it used, No IDEA how to install any tips?? thanx
I assume you have the Nissan mask. I have it for my 97. It's nice, but I like the nose mask on my mom's 99 Camry better.
Well the top piece is easy. Open the hood, and then put it on and secure with two side hook straps (you'll find the holes on the hood underside). There is also a small hook to latch on to where the hood hook latches on when the hood is closed.
The bottom part is tougher. You will need two snap buttons to replace the screws in your wheelwell (one in each well). I hope the previous owner sent these to you, or else you will have to get them from the dealer. The two snaps is where the two snaps on the corner of the bra fit. Then the two "triangle" sections hook over the metal on top of the headlights, and the hoods hold on the inner top fenders. Finally, there are three hooks for the bottom section, and two hooks (with elastic straps) for the license plate area. The foam inserts go underneath the headlights (right through the rubber weatherstripping). My foam inserts have worn thin and don't hold under the headlights anymore. I just fold them into the bra and it still looks fine.
SmokinMax02
18
Sep 11, 2015 12:25 AM
Superbform
Aug 11, 2015 08:10 PM
ramtin325i
Aug 8, 2015 05:13 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
