Question About EGT Reading. It's Too Low!
Old Jun 11, 2003 | 06:43 AM
PCGuRu2K's Avatar
I got a chance to do a spirited run on an open stretch of road last night.. Basically did a run up to 160mph I noticed on my EGT that it just stayed @ 140F at that speed with my 2.87" pulley & Cartech FPR (not tuned). It seems to not pull as hard from 140-160mph. When I had my 3.33" I was tuned properly with my AFC & Vortech 8:1 FMU. The last time I did a 160mph run with my 3.33" the EGT was in the 1500+ range and I felt the car pull a lot harder from 140-160mph. I know that since my EGT is lower now that means I'm running richer. That would explain the slight loss of power at that speed. I tried raising the % on my AFC 1% higher @ the 5500 and 6500rpm range. You think that's enough?
Old Jun 11, 2003 | 11:16 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
that or you're detonating.
Old Jun 11, 2003 | 11:44 AM
a33's Avatar
a33
how did you get to 160mph??
the redline of 5thg ear is only at 150mph
Old Jun 11, 2003 | 11:50 AM
PCGuRu2K's Avatar
@ 150 I'm like above 6K RPM.. I think it's because I have a auto ecu on my 5spd.. Because 4thgear pulls to 7K while 1-3 redline @ 6500K. It's weird, but I'm not complaining
Old Jun 11, 2003 | 11:51 AM
PCGuRu2K's Avatar
hmm... I forgot about the detonating.. I'll have to pull my plugs cand check. Should I just look for like white spots on the plug?
Old Jun 11, 2003 | 12:28 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
That's one way to check...do you have any kind of visual A/F gauge hooked up to your car?
Old Jun 11, 2003 | 12:31 PM
OT n00bs FTMFCSL
That's one way to check...do you have any kind of visual A/F gauge hooked up to your car? Lower EGT's could mean running rich too, but that would be wayyyyy rich (for what you have indicated). Since the piston is going to be the one absorbing the preignition heat, that very well could explain the low EGT at those speeds...
Old Jun 11, 2003 | 12:47 PM
turbomax97's Avatar
Considering the amount of boost you're running I doubt you're possibly running rich; there's just not THAT much fuel to drop the egt's that much. Just pull the plugs and look for any white specks, or the overall color being anything other than brown.
Old Jun 11, 2003 | 12:59 PM
PCGuRu2K's Avatar
Yeah I think that might be the case.. I'm just using the 1 step cold with default gapping.. Should I change that?
Old Jun 11, 2003 | 01:01 PM
PCGuRu2K's Avatar
I did have one.. Now I just have the boost,fuel,and egt to monitor. My a/f wires are still hooked up though. I could always plug my a/f guage back in and look. But then where can I hook it up to. Ran out of space on the pillar
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
pears
Sep 18, 2015 05:25 AM
