ECU Diagnostics
Old Jun 11, 2003 | 07:44 AM
Izzrock's Avatar
ECU Diagnostics
Can error codes be pulled from an ECU even without the "Check Engine" lite illimunated? I'm troubleshooting a possible electrical problem (power seems to intermittently cut in and out for a couple of seconds while driving) and I'm getting some advice about sensors but I want to avoid replacing a working sensor. I was wondering could I run some self diagnostics and get a code even with an intermittent problem or does the problem have to constantly happen. Any help is appreciated!!
Old Jun 11, 2003 | 03:16 PM
90MiGhTyMaX's Avatar
Re: ECU Diagnostics
You should be able to get a code even if the check engine light is not on. I recomend you get the factory service manual because it has everything listed in detail (chiltons and haynes are limited with information and I know this because I own both). good luck.
Old Jun 11, 2003 | 04:47 PM
shoult's Avatar
You should be able to get a code even if there is error.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
