compression test and running lean
Old Jun 11, 2003 | 09:42 AM
on_alert's Avatar
I finally got around to replacing my stock plugs...
The platinum plugs that were in there were a little whitish/grey, indicating a lean condition, they were all about the same color.
I am using an 8:1 FMU, and have an safc, but I STILL havent had it tuned.
The highest my EGT has ever been was 790 centigrade.
My compression test (done while the engine was slightly warm - not sure if it matters) yeiled around 160 in all cylinders.
Thoughts?
-OxA
Old Jun 11, 2003 | 11:41 AM
PiotrC70's Avatar
Not sure what help I can be since I don't own a max anymore but from reading other peoples results, stock compression seems to be around 170 so all 6 cylinders at 160 is fine. That shouldn't determine whether you'd be running lean or rich. If you've installed a SAFC, it's best to go dyno and tune it on there so you KNOW what you're running for A/F.
Usually running lean wouldn't yield cooler EGT so if your EGT are low compared to other Max's, it's probably that you're running rich. (fuel is basically a coolant)
Hope this helps a little... I would dyno tune. DON'T butt dyna an AFC.
Old Jun 11, 2003 | 11:52 AM
Ramius83
I just don't understand why your's and Bags compression numbers are around 160 and mine were all around 185, which is "normal".
Old Jun 11, 2003 | 02:11 PM
BigDogJonx's Avatar
from factory is 180lbs, minumum is 142lbs, no more than 14lbs differential between cylinders.
You need to do the compression after the engine has reached normal operating temps. Doing while warm or cold is wrong cause the engine is not at normal operating temp and it can affect the test.
Dixit
Old Jun 11, 2003 | 08:19 PM
on_alert's Avatar
so i have to take the plugs out while the engine is blazing hot?!?!?!
Old Jun 12, 2003 | 06:03 AM
ejj's Avatar
ejj
I've done both compression test hot and cold. Yield about the same results (+/- 2psi).
160psi is lower than normal, but still within the acceptable range. Better than 100psi!
Old Jun 12, 2003 | 09:07 AM
Bags's Avatar
VG Ridah's Biatch Hoe
sounds like a good reason to start at 10 PSI
MAXSE5SPD
Sep 17, 2022 04:00 AM
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
Maxima30
Sep 7, 2015 06:13 PM
