SC guys (mainly V1): More power and an Eaton roots sound...belts DO make a difference
Old Jun 11, 2003 | 08:47 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Many of you have seen my threads about me b!tching about my idler pulley and shredded belt. Well, the belt I had was a razor thin cheapo belt. Completely shredded off within a few thousand miles of having the supercharger on my car. It has today been replaced with a Dayco Poly-Cog, #5060695. This belt is at least 3x thicker then my old shredded belt, with thick blocks that hug the ribs on the pullies. The guy at AutoZone said this is the next best belt to the Goodyear Gatorback.
Sound Difference: Right off the bat, I noticed that with this belt, my supercharger now emits a different tone. Not at idle, but when revving or under a torque load. It emits a Ghostly howl that sounds VERY similer to the SVT Cobra and SVT Lightnings Eaton Roots Type blowers. Well I am in love. I don't know if this is coming from the belt itself, or if it's causing the compressor to make this noise, but I love it. At WOT there is a high pitched whine that hints at the Eaton Roots howl, which really adds flavor to the overall sound. This all may sound corny but I am very happy with this.
Power Difference: I noticed right after the install, that my car revved faster and seemed to accelerate quicker. But to insure that it wasn't just my untuned butt dyno, I drove spiritedly every now and then today. I spin into second gear more on the 1-2 shift, and the RPMs rise faster in general throughout the power band. The car is quicker with a slight increased feeling in torque. I did a downshift into second @42mph, and noticed more tire spinnage, more "pushed back in your seat" feeling, and the RPMs climbing faster.
I am positive i've gained power, and it makes sense. A rubber band like belt with a shredded rib vs. a thick and sturdy Poly-Cog with all ribs tightened up to spec....just like GTR_Rider had suspected I believe I've gained back boost pressure. My car is quicker then ever before.
So people, don't **** out on your belts. You could be missing an awesome sound, and more HP/TQ. BTW, the Dayco Poly-Cog was only $29.99.
Now, to tackle the rich fuel issue...
Old Jun 11, 2003 | 08:55 PM
MaxSpeedSE's Avatar
Confused's Avatar
Permanent Maxima.org Resident
why buy next to the best?
I gained over 20hp after fixing a belt issue
good job
Old Jun 11, 2003 | 08:58 PM
Craig Mack's Avatar
good job
Wow, 20hp, nice! Why not go with the Gatorback? Well, they had none in stock and there weren't any for miles so, this is the next best thing. Cheaper too. It is a quality belt....you gotta give it props.
Old Jun 11, 2003 | 09:17 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
cm didn't you also downsize to a 3.125?
Old Jun 12, 2003 | 07:41 AM
Craig Mack's Avatar
Yes....but the shredded belt was the proper size too. We couldn't measure though becuase it was....shredded.
Old Jun 12, 2003 | 02:54 PM
Craig Mack's Avatar
how many of you experience a sound change when changing to a different type of belt? My change was significant, so that's probubly why I got it...
Old Jun 12, 2003 | 04:01 PM
BlackCat's Avatar
RIP '98 Maxima SE
I might be due for belt change soon...
Does your belt look like they have many notches that run 90 degrees across the ribs? I may have offered a Dayco belt a while ago but I turned it down because the Vortech document said to stay with the solid rib-type belt.
Old Jun 13, 2003 | 03:24 PM
BlackCat's Avatar
RIP '98 Maxima SE
This is the Poly-Cog:
I'll pick one up and give it a try the weekend after this one.
Finkle
Sep 27, 2015 09:53 PM
maxipower
Aug 21, 2015 11:10 AM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
1992maximase30
Aug 5, 2015 09:27 PM
