Another oh ****.
Old Jun 14, 2003 | 03:29 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
Another oh ****.
So, i revved up in neutral and hit 8 lbs of boost without the tranny engaged.... what the hell...
Old Jun 14, 2003 | 04:08 PM
Ramius83
And this is a bad thing????
Old Jun 14, 2003 | 04:28 PM
KLoWnPR109's Avatar
I thought there was no boost in nuetral?
Old Jun 14, 2003 | 04:39 PM
max'n out's Avatar
USally best you can do is reach balance. I don't see a problem but it is interseting, though not exactly an oh ****.
Old Jun 14, 2003 | 06:24 PM
turbomax97's Avatar
well... it's not supposed to reach any boost, only no vacuum when not in gear.
Old Jun 14, 2003 | 09:36 PM
Chunger's Avatar
My other car is a Hybrid
Not necessarily true for a S/C... the BOV will slap shut for a while and we don't need to wait for "spool up"
Old Jun 14, 2003 | 09:52 PM
turbomax97's Avatar
actually, it's true, it never used to do that..... Only recently since my tranny started going capute...
Old Jun 15, 2003 | 09:06 AM
Ramius83
But, I don't see what you guys are saying here. If you revved the engine up in Neutral, you are still revving the crankshaft. And this is moving the belts which will spin the blower. Isn't this supposed to happen anyways?
Old Jun 15, 2003 | 01:29 PM
turbomax97's Avatar
it shouldn't built boost when there's no load on the motor, like when not engaged in gear.
Old Jun 16, 2003 | 09:02 AM
Stephen Max's Avatar
It's all a matter of how the BOV is set. In most cases, even though the SC is pumping just as much air as usual, revving the engine up in neutral is done at part throttle. There's no need to rev up at WOT. Since you're at part throttle, the manifold vacuum never reaches zero, and the BOV stays open and no boost pressure is developed. If you rev at full throttle, your BOV will close and you'll make boost, but you'll hit redline in the blink of an eye. Usually faster than the boost gauge can react.
