Need help identifying SC parts
Old Jun 15, 2003 | 06:11 PM
Tanman's Avatar
Hi,
I'm trying to inventory the SC parts, and I can't identify these parts:
Can anyone help?
Thanks,
Old Jun 15, 2003 | 07:42 PM
KMax2988's Avatar
1)Belt tensinor bracket
2)no clue
3)Retainer clip for SC housing
4)Same as 3
5)no clue
Old Jun 15, 2003 | 07:58 PM
WizzaMax's Avatar
last one looks as though it is a bypass for oil or breather hose someone put together for valve cover or something of the like...
Old Jun 15, 2003 | 11:50 PM
Tanman's Avatar
2)no clue
4)Same as 3
5)no clue
Thanks for the input. Are the retainer clips supposed to be separated from the SC? I don't see them as individual items on the parts list.
Could part 2 be the fuse box relocation bracket?
Old Jun 15, 2003 | 11:59 PM
Tanman's Avatar
Yes that was connected to the valve cover breather port. I'm sure it's a standard part of the SC kit, maybe a T-adapter or something. Any clues?
Old Jun 16, 2003 | 08:56 AM
[maxi-overdose]'s Avatar
Hi Tan:
havent seen you around for a while. how's everything?
getting ready for the sti?
about the parts....have you tried the parts list stickie??
Old Jun 16, 2003 | 01:42 PM
KMax2988's Avatar
The retainer clips should be on the supercharger, they are not counted as separate. They hold the compressor housing to the turbine assembly.
Old Jun 16, 2003 | 03:32 PM
Tanman's Avatar
Originally posted by [maxi-overdose]
Hi Tan:
Hey maxi, everything is ok right now, spend most of the time working here in Wyoming. How's life for you? Looks like you're doing a lot of work on your Maxima .
I should have the STi in two weeks or a month. I'm kind of nervous since it's a high-maintenance vehicle and I need it for work. It's a pretty harsh environment here, lots of dust, snow, and rough roads. Not sure how reliable a turbocharged car with 20lbs of boost will be. Also, it looks like some dealers around here are charging $5K over MSRP. I need to get my car back to stock before I trade it in. The guys who removed my SC did a crappy job, so I'm taking inventory of the SC parts to see if any are left on the car before I trade it in.
I printed out the parts list, but I can't tell what some of the parts on the list are. Like the 5 parts in the picture. Can you help?
Old Jun 16, 2003 | 03:34 PM
Tanman's Avatar
Do you have pictures of where they go and how they are connected to the SC?
Thanks,
Old Jun 16, 2003 | 06:46 PM
Hey maxi, everything is ok right now, spend most of the time working here in Wyoming. How's life for you? Looks like you're doing a lot of work on your Maxima :naughty :.
.....same old same old here...work's the same, life's the same. spend money on a mod....study it and have fun with it for a month. Then look for another mod next month. after the water injection, I will stop modding the Maxima and start saving for a 350z roadster. (if I can convince my gf to forget about getting a TT! she really wants one)
congrats! you should have fun with 300bsp ....I've only seen one here in the bay area so far. but saw at least 6 lancer evos.....I want to run with them see how fast those little monsters are. (probably not from dead stop )
so....what does the Subaru say about breaking in the STi?? I hope it is ok to break-in the car with a turbo. or the engine is already pre-borken-in.
dust, snow, rough road are what STis are designed for since you are intercooled and water injected(?)....you should be fine for the hot summer.
I think no. 2 are from stock pulley bracket IIRC. I remembered I saw it after Kevin installed my SC. 3 and 4 are retainer clip for the blower unit. I believe no. 5 is the connector for intake piping and crank case breathe hose. I dont see this part on my car....prob because I use a crake case breathe filter. hope this will help.
Old Jun 17, 2003 | 03:56 PM
JAY25's Avatar
#2 is a alternator bracket
Old Jun 17, 2003 | 04:07 PM
KMax2988's Avatar
http://www.maximadriver.com/modules....view_photo.php
That's the best photo I can find since my camera's down. If you look towards the top and left side, you should be able to see some of each clip.
Mar 12, 2020 12:06 AM
SpeedCrazie
Sep 16, 2016 03:41 PM
follyburr
Detailing
Jun 13, 2016 02:06 PM
Lowered_a33
Sep 10, 2015 09:41 PM
Colossus
Sep 9, 2015 05:46 AM
