Is the B&M STS really a Short Throw Shifter?
If you make the portion of the shift rod above the pivot point shorter (like a cut stock shifter) you reduce the distance you move the shifter but this tecnically does not make it a short throw shifter.
To shorten the shifter throw you must legthen the portion of the shift rod below the pivot point. If you lengthen the portion of the shift rod below the pivot point it will hit the cat heat shield unless it is modified or removed. I see no way around this.
Several people who have installed the B&M shifter claim that it is not necessary to modify the Cat heat shield. Is the B&M just a lower shifter and NOT a Short Throw Shifter? Or has B&M found some way around this?
Since it's adjustable you can move the pivot point lower without hitting the heatshield assuming you don't move the point too much. I don't remember how much clearance there is, but there is some room to play with. Your next option if you want to lower even further is to bang out the heatshield or remove it completely. I removed my heatshield because I wanted the shifter pretty low.
-hype
-hype
-hype
-hype
Does anyone have an uninstalled B&M shifter they can compare to the stock shifter?
If you shorten the part of the shifter above the pivot point it will reduce the distance you have to move the shifter but it will not increase the amount of movement on the transmission linkage. If you check my very high quality drawing
below, the shifter on the left is simply shorter (above the pivot point), the distance you move the shifter is less if you compare line A to line B, but it is not really a short throw shifter. You can get this effect by cutting the stock shifter and/or using a shift **** that sits lower.The shifter on the right shows if you lengthen the portion below the pivot point, the linkage will move more (line B) therefore shortening the throw.
Well i have it and it is so much different from stock. I dont know exactly how they engineer the shifter but i would imagine it would have to do with the amount of the shifter above the pivot point compared to the amount below. This would change the leverage and a smaller movement above would result in a larger change below therefore poping it in gear without a long throw.
SOmeone posted pics of the stock shifter with the B&M side-by-side and it looked like the B&M was longer (below the pivot) by about 1 cm. While not seemingly a huge amt, it definitely makes a big difference. I think realistically, a 30% throw reduction is the maximum before notchiness becomes a huge problem.
I have the B&M and I must say the throws are definitely a lot shorter. Takes hardly any effort to throw it into the next gear. It's so short that when I'm in 4thgear it looks like I was in "N"
I have an e-bay shifter and it replaced the stock directly. The B&M looks like it has a piece that actually moves the pivot point higher(the little purple cup). That would allow a longer portion under the pivot without interfering with the heat. At least that's my thoery.
Originally posted by mitch33x
all this talk about the B&M shifter, I really want one. Where did everyone get there's from?
Originally posted by 00MAXIST
I got mine from Tokio, great prices and fast shipping. Definitley recommend him and the B&M STS. This guy called me in Florida from San Fransisco to give me my tracking number, so I could get it sooner. I was amazed.
the STS came pretty much on time
jmlee44
Oct 2, 2022 02:13 PM
atriuum
Sep 28, 2015 01:19 PM
