Start up problem
Old Jun 16, 2003 | 05:06 PM
LatinMax's Avatar
Start up problem
As some of you know I now have a brand new engine.
But it hick ups sometime when I start it up.
Sometimes it will not start at all and I end up having to pull the fuse for the Walbro Fuel pump, crank it up, it starts then dies (of course the fuse is out) then put the fuse back in and it starts right up like a champ.
Any ideas what my be causing this?
Anyone have this problem?
Old Jun 17, 2003 | 06:59 AM
Stephen Max's Avatar
Re: Start up problem
Wow. What made you think to do that? Was the engine flooding?
Old Jun 17, 2003 | 07:32 AM
LatinMax's Avatar
Yes. You can smell the fuel.
Old Jun 17, 2003 | 07:57 AM
If it only happens when the engine is hot, then maybe it's a bad engine temp sensor. If it happens when the engine is cold or hot, then maybe a leaky or stuck open injector.
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
hmm.... my walbro died on me gabe.... i was experiencing that problem occasionally... fp would shoot up ridiculously high -> 80 psi while starting, so i had to crank it a few times....
Also, check your starter... I know we've cranked the hell outta that thing
Old Jun 17, 2003 | 08:06 AM
Wouldn't that indicate a problem with the fpr rather than the fuel pump?
Old Jun 17, 2003 | 09:02 PM
turbomax97's Avatar
i don't think so, it works fine on the oem pump.... also, since there is no vacuum to regulate the fuel via the fpr until after the car has started cranking, i don' thtink the fpr is related
Old Jun 18, 2003 | 06:09 AM
If there is no vacuum, then a normally working fpr provides 43 psi of fuel pressure (for a stock system). This is why the fuel pressure is higher at WOT when there is little or no vacuum. After the car is started, vacuum builds up and the fpr adjusts the fuel pressure downward to 34 psi.
The fact that it works fine with the oem pump may just mean that the oem pump can't generate more than about 43 psi.
Old Jun 18, 2003 | 12:35 PM
turbomax97's Avatar
sorry to ***** up your thread gabe... maybe some of this will help you too....
makes sense stephen.... read my other thread i started today in the sc/tc'd forum and post there if u get a chance
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
