EVAP canister valve install
i have a CEL with code translating to EVAP control system, which I believe means that I need a new EVAP canister valve..im not very "mechanically sound" so i called nissan and got a labor quote of around $115 for the install. first of all do u guys think that is a reasonable price and also how hard would this install be? could i or a friend with decent mechanical knowledge be able to perform this service?
Thanks for the help,
Tom
Tom
just picked my canister valve up yesterday, but didnt get a chance to put it in cuz it started to rain. doesnt look like it should be that hard to do, i def wouldnt pay $115 to have nissan put it in. I should get to it tomar or fri, ill let ya know how it goes.
Originally posted by Black98Max
How much does a new valve cost? And what codes were you guys getting? i just got a 0309 and a 0705. Do you think a new valve replacement will fix this? What about the leak? could that be b/c the valve is bad?
I was quoted $360 from the dealer for this job - parts and labor! I did it myself for $108.00 - canister and valve. You may not need to replace the canister, the valve unbolts from it (2 10mm bolts). $37 for the valve...call around, I was quoted as much as $64 for the valve. There is also an o-ring with the valve, costs about $2-$3.
I have very little experience working on cars, but this is something you can do on your own in a few minutes. Don't waste your money at the dealer.
Nj, Would this have anything to do with a rough idle?? at all? Or engine starving for gas? I got the canister valve/purge selenoid and im wondering if this could fix something.
Get the parts online.
A whole lot cheaper then dealing with
your local nissan dealer parts dept.
Try:
www.nissanparts.cc
or www.nissan-auto-parts-dealer.com
Try:
www.nissanparts.cc
i have a 98 maxima with 108K miles on it and i pulled those codes for the EVAP and one for my upstream O2 sensor
Not much yet, my cars had a rough idle problem for say 6 months now and ive done alot of sensor testing and replacing. I just got this code and im reading through some threads hearing about cleaning out the evap valves with WD40 so im gonna try that soon too.
I got the frontleft O2 sensor code about a month ago and just replaced it for 85 bucks and now this code just came.
Let me know if you find something to fix em. thanksmwest.
Originally posted by 96shogunmax
I got a new cell number 662-292-2488.I might need to do it to mine too...
Originally posted by bobjohnson
Wait Wait, First Isnt that valve permantley connected to it. Like molded. And what YEAR maxima do you own?
I bought the vapor canister and the EVAP valve, but it didn't come with any bolts. Did anyone else who ordered the canister and valve get the two bolts with it? The reason I bought the canister was cause the bolts are stripped and I couldn't get the valve out.
MaxLife17
Jun 27, 2019 01:37 PM
03VQMAX
Sep 5, 2015 03:47 PM
all ya need is a 10mm socket and about 15 mins. very easy job, go for it. good luck
