Couple new pics from my cardomain page: 13" brakes and missing MEVI valve
For reasons I don't care to go into right now (read-"my own stupidity") I am unfortunately running stock calipers on my 13" rotors right now. But they work. They work too well, hence my need for R compounds. I'll post the details of my setup and what happened later.
I decided to check my MEVI valves because people had been having problems with them. I popped off the cover and look what I found.
You can see one screw to the left of the detatched valve. The other screw was in the little opening below and between the two Ws in the text I wrote on there. I don't know what happened to the little arrow I had put on there. I got lucky.
Originally posted by MaximaMoJo
I would go buy a lottery ticket if I was you.
Neal, did you use loctite or anything? I assume that was my mistake...but if you did...
This seems to be getting more and more common.
Re: Couple new pics from my cardomain page: 13" brakes and missing MEVI valve
Are they much better than stock?
Re: Re: Couple new pics from my cardomain page: 13" brakes and missing MEVI
Originally posted by ejj
What was involved to make the stock calipers work the the 13" rotors? Could this be a semi-break upgrade for people that can't use Z calipers because of their wheel offsets (read: ME!)?
No i didnt use loctite I just tightened them down real good with a large screw driver rather than the puny one I used before. I will be putting some superglue or something on them later, but my MEVI is out of commission right now anyways, I fried my harlan switch somehow.
Very nice work Nealoc. But you have made lemonaid out of lemons in this case. The Cobra rotor + stock calipers should be a very nice compromise brake upgrade kit. Especially if they work even nearly as well as you experienced.
Re: Re: Re: Couple new pics from my cardomain page: 13" brakes and missing MEVI
Originally posted by Ramius83
Neal: Aren't those your 15 inch Kosei's?????? If you are using the stock calipers there, won't the 300zx calipers touch the inside portion of the rim? Anyways, I would like to talk to you about the bracket you used.....
If I go drag racing I will either do it on my street tires or I will swap out the rotors and put 300zx rotors on.
Originally posted by teejnut
Do you think the 16" Koseis will fit with teh 300ZX calipers and rotors?
MaximaDrvr
Aug 19, 2015 08:20 PM
