Turbo boost bleds down the closer I get to redline
Old Jun 27, 2003 | 06:12 AM
Bags's Avatar
VG Ridah's Biatch Hoe
I am @ 7 PSI.. on the dyno last night from the time I start to the time I finished I lost 1/2 PSI or so. So at redline I was at 6.4 PSI
Any thoughts on what it maybe????
Or is this normal?
I like it better than boost creep, I am just trying to figure it all out
Old Jun 27, 2003 | 07:31 AM
plurco's Avatar
I can't help, but I would love to know what you dynoed at.
Old Jun 27, 2003 | 07:53 AM
Chunger's Avatar
My other car is a Hybrid
Since boost measure is actually "residual" pressure and it looks like you have MEVI, your engine may be better using that pressure/air the turbo is generating more so less "residual" pressure is measure near redline.
Unless you have an electronic boost controller....
Old Jun 27, 2003 | 09:15 AM
Bags's Avatar
225 WHP 235 WTQ( I think ) @ 6.8/7 PSI
and with an A/F ratio of 11:5 and a NON working MEVI
The dyno chart will be up today..
Just have to get it loaded and I can't do that here
chunger, yes on the MEVI and NO it was not working..
and manual boost controller
But I DO understand what your saying.. thank you
Old Jun 27, 2003 | 11:42 AM
Ramius83
Also, as it may be the case with a T3/T4, may the T3 side be "choking" in the upper RPM band??????
Old Jun 28, 2003 | 12:12 AM
on_alert's Avatar
its actually common and some boost controllers with an RPM offset will adjust for it.
-ctn
Old Jun 28, 2003 | 08:52 PM
qnpark8282's Avatar
-ctn
its the mevi. i had the samething. u have a leak somewhere on ur mevi reinstall ur mevi only way to solve the problem.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
Forge277
Jun 13, 2016 09:26 PM
