"HomeLink" question...
This is driving me nuts...
I have followed the EXACT instructions to program it like 3 times, and the little red light flashes just like the card says it should, yet it has yet to open my garage door. Is there some trick I am missing?
Re: "HomeLink" question...
It took me a few tries to get mine working right. When you say the red light flashes...is it flashing really quick? IIRC it should flash really quick for a few seconds to confirm that it got the frequency. I tried a bunch of different ways of pointing my existing receiver at the Homelink one, eventually I got it by holding it literally 2" away from the sun visor and I already had the button on it held in when I started holding the 2 Homelink buttons.
Yeah the red light flashed just like it says it should, fast, slow, whatever it said it should do, it did. It shows a pic of how you should hold the remote right up against the visor, so that's what I did. I'll try & find the opener instructions, though - that's a good idea.
Listen to Padsy & Maximax, even though the Max has it's own instructions - follow the opener's instructions.
I have a Genie Xcelerator and the instructions are almost the exact opposite of the Homelink on the Max.
IIRC, after resetting the Homelink (e.g. Page 2 of the instruction card) do the opposite of what it says. Press the Opener's learn button first - then the Homelink's.
It took 2 people to program mine.
Me on ladder in garage holding in programming button on opener, wife in car pressing homelink button. Kind of a pain but that's what you have to do with rolling codes.
Programming the gate opener was much simpler - it didn't use a rolling code so I could follow the instructions that came with the Maxima.
I thought i'd need two people myself, but i instead parked the Max under the Garage door opener - opened the driver-side door and used the sill-area as my step-up to reach the opener with one hand and press the homelink button with another
Mine was a pain in the *** also.... now it works but my new problem is that we have two garage doors and they have the same type of door opener. When i push the home link button both f***ing doors or close. Anyone have a solution to this ??????? Please help.
If you can't get it to work after repeated attempts, the Homelink may be faulty. Try to program it using your neighbors or relatives door opener. If it does not program that one, take it to a Nissan dealer and get it replaced under warranty like I did. They put in a new one and it works fine.
I took my shoes off and opened the sunroof
Most garages (e.g. apartments, etc) usually have an RF-type opener in conjunction with the parking cards.
Try asking the building management if they offer RF controllers you can borrow (usually for a monthly fee).
Originally posted by lcf
Does 'Homelink' have to be reprogrammed after the battery is disconnected?
