1990 Max SE engine to sentra?
My 1990 Maxima SE has a transmission going out, but the engine is strong. I haven't found any transmission donor Maximas or any with a blown motor to do a swap yet. Does anyone know if I could put my engine in a sentra? If so what year and model would work? Does it require serious modification. If it worked, I'd have a kickin' sentra. I did a quick search on this and didn't find anything.
Any suggestions
Fid
Any suggestions
Fid
Well, I don't think such a conversion as this has ever been tried, which may explain why there's no info on it. The transmission would be a huge problem...the Sentra tranny wouldn't be able to cope with the V6 power and torque characteristics.
Also, putting a 160HP V6 in a Sentra that came with an engine that probably already made at least 100 HP is a strange way to gain ponies. You'd be better off modding the 4-pot in the Sentra than swapping for a V6. That's how I see it anyways.
Thanks for the replies. If I remember right, there was a Red 94 Sentra SE-R on EBay with a Maxima engine in it. The guy said it ran OK but you could hear the engine clunk into the firewall when you put it in reverse.
Re: 1990 Max SE engine to sentra?
Any suggestions
Fid
Any suggestions
Fid
Dumbass!!! Even if you could squeeze max engine & tranny into Sentra (after re-positioning the firewall or adding a new nose...), you'd have to change front suspension & brakes, figure out where to mount the remote brake booster, locate the battery in the trunk - along with the lead weights to offset the extra weight in the front...) & then modify the rear suspension & brakes to compensate for the extra weight in the rear. Plus... try & get that bad boy certified! Word to the wise:
REPLACE YOUR TRANSMISSION - IT'LL BE CHEAPER & QUICKER...
NismoBaron Knows Best
MAXSE5SPD
Sep 17, 2022 04:00 AM
