is there a fi 02 or 03 car out there?
ive got an 03 6spd car and want to get it done...id like to know if anyone has done a 3.5 car yet and if so where to get it done?if not who to go to to be the test dummy...
any help would be appriciated
thanks
tony
thanks
tony
Re: is there a fi 02 or 03 car out there?
thanks
tony
thanks
tony
Re: Re: is there a fi 02 or 03 car out there?
Originally posted by SmokinOdum
I also would like to know this. Im interested in building my own setup. Also what differences would there be between a 2001 and 2002 besides the piping?
so what options are there for the car?i guess nobody has a f/i car?whose doing the turbos on the other 5th gens around dc well **** on the east coast?
there are few tubo 5th gens...but they are 2k, 2k1s. like Cbass said, 2k2+ have a returnless fuel system and the vairable timing module is right on where a centrifugal SC would mount.
there is a SC kit for 350z by procharger...I dunno if there is anyboy looking into this yet.
Originally posted by purple max
Any super charger would not fit under an 02-03 max or 350z. If I were you I would get all the boltons, fuel pump and a 100 wet shot of nitrous. That should be good for at least 350 hp at the wheels.
Originally posted by [maxi-overdose]
N2O!
N2O!
yeah motors the same... good luck on fitament, dont know about that.
Edit: Not to mention that with the sc kit, stillen made 305 .... @ 7 lbs boost.... and that's with the stillen exhaust system. Not very impressive at all.
Originally posted by CBass69187
Upper intake manifold is different.
now i thought ive seen in here somewhere that someone found the maniflod works on a max but there is a hood clearance prob.....right?i can get manifold and t/b and all hardware for 900
if thats all it takes to make a s/c work im in.....unless there is someone out there that wants to turbo my car....but cant find anyone.....
It should work, the Stillen blower for the 350 replaces the upperintake mani.
Tony give Greg from Custommaxima a call, The company that is building the turbo for my car would probably do your car with no problem! Just be prepared that your car will be down for a couple of weeks.
Originally posted by Pinnacle
s/c maybe only 7-8, but the turbo should handle more than that..
huh? boost is boost...doesn't matter if its coming from an SC or Turbo, the motor can only hold what it can hold.
Lakersallday24
Jun 16, 2019 01:35 AM
yat70458
Aug 3, 2015 01:16 PM
