is there a fi 02 or 03 car out there?
Old Jul 4, 2003 | 06:27 PM
tonylittell's Avatar
WANNA RUN IT?
ive got an 03 6spd car and want to get it done...id like to know if anyone has done a 3.5 car yet and if so where to get it done?if not who to go to to be the test dummy...
any help would be appriciated
thanks
tony
Old Jul 5, 2003 | 08:53 AM
SmokinOdum's Avatar
Re: is there a fi 02 or 03 car out there?
thanks
tony
I also would like to know this. Im interested in building my own setup. Also what differences would there be between a 2001 and 2002 besides the piping?
Old Jul 5, 2003 | 10:23 PM
CBass69187's Avatar
Re: Re: is there a fi 02 or 03 car out there?
Fuel system is different and if you go SC, you cant mount it on the left side of the engine.
Old Jul 6, 2003 | 08:33 AM
WANNA RUN IT?
so what options are there for the car?i guess nobody has a f/i car?whose doing the turbos on the other 5th gens around dc well **** on the east coast?
Old Jul 7, 2003 | 01:03 PM
[maxi-overdose]'s Avatar
N2O!
there are few tubo 5th gens...but they are 2k, 2k1s. like Cbass said, 2k2+ have a returnless fuel system and the vairable timing module is right on where a centrifugal SC would mount.
there is a SC kit for 350z by procharger...I dunno if there is anyboy looking into this yet.
Old Jul 7, 2003 | 01:23 PM
CBass69187's Avatar
I was thinking that it may work to have an upgraded fuel pump, and a seventh injector with the HKS AIC, but it would be expensive.
Old Jul 7, 2003 | 07:36 PM
WANNA RUN IT?
what about turbo?would that be easier?
Old Jul 11, 2003 | 02:55 PM
purple max's Avatar
Any super charger would not fit under an 02-03 max or 350z. If I were you I would get all the boltons, fuel pump and a 100 wet shot of nitrous. That should be good for at least 350 hp at the wheels.
Old Jul 11, 2003 | 03:53 PM
CBass69187's Avatar
There are already SCed 350's. Max has room also.
Old Jul 12, 2003 | 12:58 PM
Brooklyn turbo's Avatar
I know there kits out there they had to modify the hood to fit. I am just going by what the seller of the kit says.
Old Jul 12, 2003 | 01:38 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
yeah you're right, they have the roots type blower with a modified hood, since the blower sits directly on the top middle of the motor.
Old Jul 13, 2003 | 03:41 PM
WANNA RUN IT?
Originally posted by [maxi-overdose]
N2O!
well i should be able to use the z s/c if i want a hole in my hood right?motors the same isnt it?
Old Jul 13, 2003 | 03:43 PM
turbomax97's Avatar
i think the z motor is mounted 90 degrees differently.
Old Jul 13, 2003 | 03:47 PM
WANNA RUN IT?
mounted differant in frame but motor is exact as far as parts right?
Old Jul 13, 2003 | 03:52 PM
turbomax97's Avatar
yeah motors the same... good luck on fitament, dont know about that.
Edit: Not to mention that with the sc kit, stillen made 305 .... @ 7 lbs boost.... and that's with the stillen exhaust system. Not very impressive at all.
Old Jul 13, 2003 | 03:54 PM
WANNA RUN IT?
thanks....what about fuel pump and injectors?what you recomend?
Old Jul 13, 2003 | 04:03 PM
CBass69187's Avatar
Upper intake manifold is different.
Old Jul 13, 2003 | 04:08 PM
WANNA RUN IT?
now i thought ive seen in here somewhere that someone found the maniflod works on a max but there is a hood clearance prob.....right?i can get manifold and t/b and all hardware for 900
if thats all it takes to make a s/c work im in.....unless there is someone out there that wants to turbo my car....but cant find anyone.....
Old Jul 13, 2003 | 04:58 PM
CBass69187's Avatar
It should work, the Stillen blower for the 350 replaces the upperintake mani.
Old Jul 13, 2003 | 10:37 PM
purple max's Avatar
Only 7psi? I thought the 3.5 block could boost at least 9-10psi safely?
Old Jul 13, 2003 | 10:59 PM
Redmax's Avatar
Redlinemax Owner
Tony give Greg from Custommaxima a call, The company that is building the turbo for my car would probably do your car with no problem! Just be prepared that your car will be down for a couple of weeks.
Old Jul 14, 2003 | 04:35 AM
WANNA RUN IT?
thanks guys......for the help...ill call greg tuesday
Old Jul 14, 2003 | 07:34 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
Um, there is a kit available for the 350z and g35coupe that required no mod to the hood and it clears. Its a procharger kit by ATI.
Nitrous is the only f/i on a 2k2/3 that I am aware of
Old Jul 14, 2003 | 10:26 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
how did you come to that conclusion?
Old Jul 14, 2003 | 11:02 PM
purple max's Avatar
I dont know. I would like to know how much a 3.5 bottom end can hold.
Old Jul 16, 2003 | 09:12 AM
Pinnacle's Avatar
edit: misread earlier post
BTW, is that 305 from Stillen at the wheels?
Old Jul 16, 2003 | 10:24 AM
DA-MAX's Avatar
Originally posted by Pinnacle
s/c maybe only 7-8, but the turbo should handle more than that..
huh? boost is boost...doesn't matter if its coming from an SC or Turbo, the motor can only hold what it can hold.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
yat70458
Aug 3, 2015 01:16 PM
