1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
Is a 2.11sec 60' time OK?
Old Jul 4, 2003 | 09:47 PM
Nealoc187's Avatar
SLOW
Re: Is a 2.11sec 60' time OK?
You already know the answer. What were the rest of your 60' times?
Old Jul 4, 2003 | 11:36 PM
BadKarma99-4spd's Avatar
holy ****, you got one fast auto max
Old Jul 5, 2003 | 12:59 AM
Y2KSESteve's Avatar
Thats a great 60' time...
Old Jul 6, 2003 | 09:10 AM
Blu's Avatar
Blu
the tits
so what where your times and traps?
Old Jul 6, 2003 | 06:01 PM
Nealoc187's Avatar
SLOW
Look at his sig.
Old Jul 6, 2003 | 06:15 PM
Blu's Avatar
Blu
the tits
Originally posted by Nealoc187
Look at his sig.
DOH! I didn't know if that was one of his recent runs with the 2.1 60's.
Old Jul 6, 2003 | 11:21 PM
1FSTMAX's Avatar
Props on the new times!
He pulls on 5 spd's! Not mine though
Old Jul 7, 2003 | 10:25 AM
1FSTMAX's Avatar
Originally posted by slammed95
You know you get owned too. Wait till the 5speed swap is completed.Muwahahaha!!!!
Wait till i get a y pipe.
Old Jul 7, 2003 | 09:51 PM
luckee2bhere's Avatar
2.11 is rediculous in an auto!!! how come i cant pull that?
Old Jul 10, 2003 | 03:45 PM
roastduck88's Avatar
Went to the local 1/8 mile track yesterday and was able to pull a best 60' time of 2.11. Is that pretty decent for a N/A auto with 17" street tires? Temperature was in the low 90's so engine timing was being pulled back at lower rpm's, robbing some torque.
Usually I use smaller tires on my steelies, but was too lazy to swap wheels. On average the steelies give me .1-.15 seconds of advantage over the 17" wheels.
Hopefully next week I can pull some 2.0's if I use the steelies and take out the interior.
Congrats to Larrio for finally racing his car.
What the heck did you do to get that kind of 60' time?? How did you launch?? Details details, and more details!! I get 2.4 60' time =(
Old Jul 10, 2003 | 09:23 PM
95CustomMaxima's Avatar
Great 60' time.
Old Jul 10, 2003 | 11:53 PM
Re: Re: Re: Is a 2.11sec 60' time OK?
Well after many, many trips to the track I ditched the torque brake method of launching. Best 60' I could pull was 2.21 by torque braking.
My new method is to barely rev the engine above idle, about 800 rpm.
Hold the brakes, and floor it on the third yellow.
Launching from an even lower RPM would be better, but the ECU is using the IACV for most of the air going into the engine, therefore throttle response is pretty slow.
This will make you have slower r/t's so you'll have to relearn.
After doing some mathematical calculations I came up with an answer as to why this works better. The inertia of an accelerating engine and flex plate/TC is harder to slow down than an engine spinning at a steady rate. That's why many domestic's use auto's with a high stall TC and heavier than stock flex plate.
WoW! Thanks! But how'd you get 2.2 from using torque brake? That's VERY impressive. My friend with a rear wheel drive got 2.3!
Did you lower the PSI on your tires at all? What kind of tires are you using?
Old Jul 14, 2003 | 12:03 PM
Re: Re: Re: Re: Re: Is a 2.11sec 60' time OK?
2.2's are no problem when torque braking in a maxima.
I only lower the tire pressure if I have traction problems. Lower psi= more drag. I'm running 235/45/17 Falken 451's at 34psi.
Wow, either way, very impressive!
Old Jul 27, 2003 | 06:51 PM
you think torque braking in a prelude works well too?
we have tried both ways in my friends but it seems its the same. i did tell him when he goes to the track i think leaving it in drive is faster than shifting with triptronic.
Old Jul 27, 2003 | 07:25 PM
Dev's Avatar
Dev
nice times...esp for an auto
just wondering what other maxima's pull off for 60ft's at your track in comparison to you
because 2.1 just does not happen at ours
Jim got a 2.2 with slicks at our track N/A...
i don't see how street tires w/ 17's can outlaunch slicks with light rims
Old Jul 30, 2003 | 01:23 PM
Dev's Avatar
Dev
The other maxima guys are pulling 2.25-2.38 on average.
As long as tires aren't spinning, then slicks aren't needed. I can't use my steelies for much longer because I'm gonna be installing some big brakes. No more 15's or 16's.
i see...the last day i went to the track...most couldn't get into 2.2's
friend of mine with a 4th gen with ypipe (auto) easily burns right through first at our track...meaning its much less sticky than normal streets.
i guess the prep work is different from track to track...(or just non-existent at ours )
Old Aug 3, 2003 | 05:05 PM
dphewko's Avatar
wow andy, u didnt bring that up. my best 60' was 2.38 but most were 2.4's
Old Aug 5, 2003 | 06:31 AM
VQdriver's Avatar
neal, whatcha been up to?? what's up with the funky sig time? you should remind all the new people that you have the quickest NA time!
Old Aug 6, 2003 | 07:38 AM
Nealoc187's Avatar
SLOW
But that's no fun
Anyways not been up to much. May have gotten scammed for $1100 on some wheels I bought over 2 weeks ago that still have not showed up though
Old Aug 6, 2003 | 08:22 AM
Blu's Avatar
Blu
the tits
But that's no fun
I thought I was getting scammed over a $50 stock airbox but I finally got it after 6 weeks. Good luck and I hope you get your wheels soon. SSR Comps right?
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
