Ok.. I am going to an 8:1 fmu
Old Jul 6, 2003 | 06:20 AM
Bags's Avatar
VG Ridah's Biatch Hoe
I am going from my 10:1 to an 8:1 FMU.
I am @ 7 PSI at about 11.4:1 A/F
I keep reading on boosted motors 12.5:1 A/F is ideal is this true?
I WILL be getting a SAFC, just can't afford it right now, getting the 8:1 fmu for free from bosco, THANKS BOSCO .
So I am just curious what is the best A/F while still being safe
thanks
Old Jul 6, 2003 | 07:10 AM
MardiGrasMax's Avatar
12.5 is purty good.
Old Jul 6, 2003 | 09:43 AM
Bags's Avatar
Originally posted by MardiGrasMax
12.5 is purty good.
Thanks matt
Although I do not know if I will get 12.5:1 with an 8:1.. but as long as it is close I'll be happy.. if it is 13 or higher I'll put the 10:1 back in
Old Jul 7, 2003 | 11:35 AM
[maxi-overdose]'s Avatar
Originally posted by bags533
Thanks matt
8:1 will make you run rich for sure. but you are getting S-AFC...so you will be able to adjust the AFR. I found the cheapest way to go is just get the adjustable FMU. S-AFC is kinda expensive. I dont think 10:1 is necessary. with an 8:1, I've already seen over 100psi of fuel pressure at WOT, 10psi of boost.
Old Jul 9, 2003 | 07:28 AM
96BLUMAX's Avatar
What are you usign to get your accurate AFR?
Old Jul 9, 2003 | 07:56 AM
I dont have anything to tune my car. still running super rich since last dyno. you can adjust your AFR with S-AFC or adjustable FMU.
Old Jul 9, 2003 | 09:10 AM
Bags's Avatar
dyno o2 sensor
max'n out
Jun 18, 2002 08:16 PM
max'n out
Jun 17, 2002 06:14 AM
redmaxpa007
May 21, 2002 11:32 AM
TimW
32
May 15, 2002 12:33 PM
j0e-
Apr 23, 2002 09:50 PM
