Starting my own turbo project
I am starting my own turbo project and was wondering what you guys thought about the best wategate for my turbo. It needs to be externally wastegated and i could either go with a delta gate or just a regular external. What are my options? Also waht about a boost controler? How would that fit in?
Thanks,
Justin
Thanks,
Justin
Originally posted by 96BLUMAX
Oh time is no problem for me.
Kudos to you and your kit fab'ing.
I'm putting one together, but I'm having all the piping done by an exhaust performance shop for about $350. Definitely worth the money.
Beats welding and bending it all myself.
Originally posted by BoostedED9
does anyone make/sell the exhaust flanges to make custom turbo manifolds?? or do people just rig something up off of the stock manifolds???
http://forums.maxima.org/showthread.php?threadid=231528
and I'm sure if you have access to a serious machine shop and some VQ manifold gaskets lying around you could throw together a real nice turbular manifold.
thanks.... i dont really like the whole design of runing the y pipe all that way back around and up. if i decide to go with the turbo in the maxima my friend has some ideas already for it so who knows how it owuld turn ot, just know that it would be good...
a little OT but how much can a stock clutch handle??? thats the only thing im really worried about if i go turbo and im sure its not the easiest thing to change on a fwd v6.
We could make one at our shop. We're actually working on some flanges right now to make a tubular manifold in our spare time. But the question is, will it be worth it to make a custom turbo manifold? We're just doing it as an exercise in fabrication, and because we thought it would be cool. The manifolds are so short that a custom tubular one wouldn't flow all that much better than the reverse Y setup a lot of people are running off of their stock manifolds. Maybe port out the stock manifold would be a better option.
does anyone have any pictures of the manifolds on the motor, i want to see how far down they actually go... i work at a shop as well and my friend always bugs me to let him make a turbo kit for the maxima since we do alot of custom jobs, so im giving in probably...hehe... just need to know more about hte motors capabilities and its stock drivetrain capabilities...
typing a long *** response then having it get deleted cause the website ****s up sucks.
cliff notes: building a kit is really not worth it. If you are worried about changing a clutch, a turbo kit is 1000 X as hard.
im a cynical bastard today
making hte turbo kit to me is easier than changing a clutch on a fwd v6, seeing as i ahve installed many turbo kits on cars. why do you say building a kit is not worth it?? i work at a shop thats what we do.....
i just want to know what the threshold of the stock clutch is and at what point of power it should be changed at.
The clutch on a Maxima isn't that hard. A turbo kit is.
A FWD V6 turbo is a whole different thing than a Honda turbo. We just custom built a turbo kit for my girlfriend's Integra. Very easy, the Maxima turbo is much, much more difficult. There is no room to work.
If you're even considering a turbo, change out the stock clutch. It won't really even hold at low boost. And seriously, if you're worried about changing out the stock clutch, don't consider a turbo kit. If you work at a shop, then the clutch should be easy.
i dont only build honda turbo kits man, we build them for every car so i know how it is to work with little spaces. one real reason im so worried about hte clutch is that i wanted to see if i could ride around on the stock one till i get my other clutch. if i have to change it then ill do it i just hate doing fwd cars they are pain a on the ***.
external wastegates - why do we have to use them instead of remote wastegates on our cars?
BTW, what turbo did you guys go with? i was looking at a 60-1 and the compressor maps look good with the numbers Ive run. feedback is appreciated...
one last thing - where are all of you guys with turbo shops? anyone in/near Florida?
You could go w/ an internal wastegate, but an external provides better and more stable boost control.
And the shop I work with is in Atlanta, GA. Where in FL are you?
I don't think wastegate capability is a problem with any boost a stock engine can handle
This is very true. I guess I'm just used to seeing high boost DSM's, Supras and SR20DET's. Those guys run 20 lbs + all day. But on a low boost motor, it's really not a performance issue. I personally prefer external, but that's just me.
I will save my comments until I know exactly what you meant by your post.
yes, thats what hes saying. not so much a "good" flowing wastegate, but the need for an external on low boost situations isn't necessary. internal wastegates don't really show signs of leakage until boosting in the teens ...I will using stock Mitsubishi TD04 and and stock internal watstegate on my Integra, most Eclipses run these up to 15psi before any signs of major leaks or spiking.
As far as internal gates starting to leak - all depends what spring you have in there. You can get an internal gate with a 17psi spring and hold 25psi with out the flapper door being blown open. Also the stock 1G DSM 14B turbo actuator has an 11psi spring - I have ran a 16G (same actuator) up to 22 psi with no noticeable leakage.
I would never do a turbo setup again using an internal gate.
Originally posted by mingo
imo delta gates are garbage.. if you want to go with turbonetics then at least get the racegate. hks wastegates are real good too, but very pricey.. i recomend the tial 35/45mm hybrid
Tial/HKS is the only way to go.
Originally posted by TellschMax02
Not sure if you know this or not, but the Tial 35mm is discontinued. Although some shops may still have some stock, they have been replaced by the Tial 38mm. If you were getting a new one I would get nothing less than the 38mm.
sorry i made a type it's 35/40mm hybrid.. i thought the hybrid was a new model?
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
