disabling ABS
disabling ABS
I did a search but did not come up with any useful info on this. But does anyone know how to safely disable the ABS system? i know that disabling the ABS system probably isn't safe...but i'd like to do that anyway. temporarily at least.
I was planning on simply disconnecting the 4 wires that plug into it. Is that all there is to it? or am i missing something?
any help is appreciated.
i pulled the fuse and my front wheels got extremly hot and my front rotors and pads were smoking. do you think if i pull the wire harnesses it would be any different, or should i say any better?i would appreciate any help i can get. my accuator keeps buzzing, just looking for a temp. way to fix this
Have you considered pulling the relays?
best advice, look at a manual, figure out how it all works, then decide how to go about disabling it. Get a througho under standing on how the system works before you tamper with it. Once you under stand how it works.
I have a feeling that people are hesitant to help you out because this is really a dangerous and "worthless" modification.
