BOV - it did not fire @ 10psi?
Old Jul 20, 2003 | 11:44 PM
[maxi-overdose]'s Avatar
recently I noticed that my BOV doesnt sound like it's working at high boost. usually at 5psi of boost....it sounds like psssssssssssssshhhhhhhht zooooooooooooooooooo. but now at 10psi and close the throttle, it sound like psssshttt. It is a lot shorter than before and I have not clue what caused it. it's because I closed the throttle too fast? I am now worried that it might damage the blower soon in the future.
what would I noticed when the BOV is not open at high boost?
it's my BOV dead?
if so, can I lubricate it with something?
thx
Old Jul 21, 2003 | 05:44 AM
BigDogJonx's Avatar
Almost sound like the BOV is jammed or the spring internally is stuck/become hard.
Dixit
Old Jul 21, 2003 | 07:12 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Do you give it gas right after letting off at 10 psi?
Old Jul 21, 2003 | 07:17 AM
thx dixit for your reply....I will give greddy a call today to see if I can do anything about it.
nope. if it didnt release, there will be a lag if I tried to give it some gas after 10psi, right?
Old Jul 21, 2003 | 07:28 AM
Y2KevSE's Avatar
If it did not release, you should not get lag (except for auto tcm lag).
Old Jul 21, 2003 | 07:30 AM
I see...thx, I will give it a try again.
Old Jul 22, 2003 | 05:42 AM
Jer's Avatar
Jer
Got another BOV you can try out (oh wait, it's probably welded on, huh ) This one sounds somewhat busted up!
Old Jul 22, 2003 | 08:30 AM
Hi Jer....I tried Kevin's method yesterday and I didnt noticed any lag. I boost up to 8psi and I did let go off the pedal and didnt hear much BOV. I quickly tap the gas again and It still go. I dunno if my BOV Is too loose or too tight. I checked the vacuum hose too, it is in good condition.
in the end, I might have to send it back to Greddy for inspection thru my friend's shop. the flange is welded on but the BOV can be taken off. If I do it this way, I will have to get a loaner BOV from someone, somewhere. or I can go with no BOV and be really gentle on the pedal.
Old Jul 22, 2003 | 10:01 AM
Jer's Avatar
Jer
Weird how it just "happened". Too loose... I'd get mighty suspicious of my friends and close ones. Your BOV is just like your woman - if someone else tightens or loosens, it will be noticed.
Old Jul 22, 2003 | 12:39 PM
I forgot to mention....I was messing around with it and I think that's how it got loose.
I wish my woman can be adjusted by a nut and a screw.....or maybe two nuts and a screw....
Old Jul 22, 2003 | 01:21 PM
Jer's Avatar
Jer
so true...
TKHanson
Nov 24, 2018 01:39 AM
BkGreen97
Apr 2, 2016 05:47 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
