fuel setup
Old Jul 21, 2003 | 09:58 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
fuel setup
now that i have a aem fpr... I'm getting fuel alright as far as being safe it seems.... except at the top end.
I'm hitting 80-85 psi @ 11 lbs boost on the 8:1 fmu....
I'm leaning way out up top right?...
I had a Mustang GT pull hard on me today... sucks.
Old Jul 22, 2003 | 12:05 AM
BigDogJonx's Avatar
Somethings a tad wrong, cause at 11psi you should be putting out (11x8)+17 which is 105psi on the fuel pressure gauge which you be close to lockup.
you sure you dont have a 6:1 in there? cause 6:1 makes your numbers more aline with the disc. which is right around 83psi when you are at 11psi boost.
Dixit
Old Jul 22, 2003 | 03:19 AM
Bags's Avatar
VG Ridah's Biatch Hoe
Re: fuel setup
I thought the only way to know if your leaning out was using an A/F gauge or EGT gauge ?
Can you use fuel pressure to determine it?
Thanks, sorry for the noob question
Old Jul 22, 2003 | 06:08 AM
Stephen Max's Avatar
Re: Re: fuel setup
If you have dyno-tuned and you know the optimal fuel pressure you need to be just right and you get less than that, then you know you're running lean. But I would think it would be very difficult, if not impossible, to determine your optimal fuel pressure without a wide-band O2 sensor and dyno-tuning.
Old Jul 22, 2003 | 12:20 PM
turbomax97's Avatar
well i was using that formula that was mentioned above... and i HAVE to be leaning out if i'm running 15 psi less than i should.... maybe i need to just ditch this pos vortech and get a cartech... i guees i could always try switching discs.
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Forge277
Jun 13, 2016 09:26 PM
