stock vg injector size
Re: stock vg injector size
Originally posted by mtcookson
what is the stock size of the injectors on the vg?
some guys on z31 say 259cc
http://www.zcar.com/forums/read.php?...90#reply_55192
strange...I was always under the impression they were less
time to do more digging!
BINGO!!!-->
http://www.zcar.com/forums/read.php?...83#reply_54496
VG30ET = 259cc
VG30E= 178cc
that 259 will still suck probably once you get in the double digits of boost
VG30ET = 259cc
VG30E= 178cc
Bosch hose end fuel injectors OHM's CC/Min Lb/hr
#0280 150 036 2.2 495 47
I wonder, would I have to fab new connectors to make these work with my stock VG engine? I'm thinking to upgrade in the future w/ turbo and/or VG33+ swap, so would this be advisable now or would be it decrease performance/MPG efficiency unless boosted?
Also, what is the best way to test current injectors?
I have 370cc and they flow no problem up to 15lbs of boost. Also they drop straight in plug and play. The stocks are 185cc according to nistune. That is on my 91 VG. Yes the turbo z31s are 259cc I happen to have spare set laying around if anyone needs.
What condition are they in?
Do you need to upgrade anything else when you upgrade the injectors, like the fuel pump?
Does the a/f mixture run more rich with larger injectors or does the ECU regulate the fuel flow regardless or injector size? (Does having larger injectors just raise the ceiling of maximum flow/pressure and leave the low end stock?)
And, how much would you be asking for the Z31 injectors shipped to FL, 32615?
Thanks.
I was doing a search about injectors since my VG seems to be running rough and came upon this old thread. I looked up Mercedes 450 injectors on eBay and found this info:
Short of having them flow tested, the best way to check injectors in your car is to make sure the coils are in spec (check the resistance)
The best way to determine what injectors will work best for you is to calculate your HP goals, and the HP capabilities of the injectors. 370cc injectors are good for around 325HP (stock FP and 80% duty cycle) while 259cc are good for about 225hp.
Lastly, 370cc injectors are far from "plug and play". There are 2 styles of 370cc from the z32, based on which style injectors your car came with you need to match your type with the 370s. You also need some type of fuel control to keep your engine from flooding.
I happen to know Jeremy and Im familiar with his setup. He doesnt have 370cc injectors, and his turbo is a T4 making 400WHP at 18psi. You are making less than 300whp @15psi and he is making more than 100hp more on just 3 more PSI. This is exactly why you cant compare boost pressure between two turbos, its the amount of air it can flow. The flow directly relates to power, not the pressure.
What is that supposed to mean? Please elaborate on your point.
Well, truth is, I most likely will just replace a bad injector with a good stock one or another Nissan injector which is more or less plug and play. I would like to upgrade in the future if I happen to build the engine, so that is why I am doing my research now, but I don't even know if it is the injectors that are giving me the problem.
Basically, the engine is misfiring. I'm not sure what is causing it. I just gave it a tune up (NGK plugs, wires, cap, rotor, fuel filter, oil change...). So, I'm assuming it must be the injectors. It was running pretty well last week for a few days before it started running rough. Maybe it's the coil? Any ideas?
