sputtering
Old Aug 17, 2008 | 08:58 PM
92MAX92's Avatar
sputtering
My 92 max se will run fine but once in a while it will lose power and start jurking check engine light goes on then it might last a few seconds or sometimes like a min and then it runs fine check engine light goes off its was happening like once a week but now its becoming more common sounds like my cat is clogged it sounds like the sputtering is coming for it any help???
Old Aug 17, 2008 | 09:00 PM
burhan92SE's Avatar
pull out the codes from ECU first....
edit : http://forums.maxima.org/3rd-generat...-then-off.html
http://pages.cthome.net/bbachinsky/nissan_ecm_codes.htm
Old Sep 10, 2008 | 07:05 PM
Jordan91SE's Avatar
You might want to check the plugs, dist cap, and button. Sounds like one of these could be bad and these would cause that problem. Also, you might have gotten a bad tank of gas. Add some ISOHeat to the tank and see if that helps.
Drunk Uncle
Apr 5, 2003 03:59 PM
blakkrob
Oct 10, 2002 07:47 PM
Jopa416
Sep 20, 2002 12:58 PM
89gle-grey
Aug 15, 2002 02:36 PM
