2k2 pulls to the right.
Old Jul 25, 2003 | 08:10 AM
2002Maxxxima's Avatar
Ok, so my 2k2 6-speed with HLSD has started pulling to the right under normal driving. At freeway speeds it will pull hard enough to change lanes. In other words, I actually have to hold the wheel straight to stay in my lane.
Anybody have any clues as to what is going on? I have 21K miles so it should be covered. I do notice too that when I turn right it is a lot easier to squeal the passenger front tire.
Any input would be appreciated.
Old Jul 25, 2003 | 08:14 AM
NT2SHBBY
need alignment or wheel weight got knocked off
Old Jul 25, 2003 | 08:38 AM
2k2kev's Avatar
It's chrome alright...
check tire pressure.. I just did and found the fronts were 3 pounds different. Making them the same straightened my car out.
Old Jul 25, 2003 | 08:43 AM
bigdo26's Avatar
ya, just an alignment should take care of that. hit any pot holes recently? i had a pulling problem in my old car which an alignment fixed immediatly.
Old Jul 25, 2003 | 08:58 AM
Maximax2's Avatar
Re: 2k2 pulls to the right.
Could be tire pressure, my 2k3 is very sensitive to this for some reason
Could be alignment
Could be that you have tread separating or are experiencing radial steer from one of your tires. Radial steer would be a little odd since you haven't had it since day one (unless you just rotated your tires).
Anyway, if tire pressure doesn't work take it to your dealer and see if they'll check it out for free if you're under warranty.
Old Jul 25, 2003 | 12:03 PM
Thanks everyone! I'll check the pressure first and let ya know!
Old Jul 25, 2003 | 05:14 PM
maximum_rpm_nyc
bad right caliper.
bad tire.
pressure difference in tires will cause minor pull not major.
alignment may cause it, but not a pull like that.
Infamous 2k2 broken lower control arm TSB/complaint.
Loose wheels ?
Old Jul 26, 2003 | 12:05 PM
Well, good news folks! The passenger front tire was way low. All better now. Thanks again.
TallTom
57
Oct 14, 2025 05:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
