Oil coming from crankcase vent?!!!?
Old Jul 25, 2003 | 02:13 PM
Bags's Avatar
VG Ridah's Biatch Hoe
My filter on my crank case has oil under it.. I am guessing it comes out when I am driving
I have let the car idle for 20 minutes and nothing comes out.. any ideas?
Old Jul 25, 2003 | 06:41 PM
LatinMax's Avatar
All I know is that when that was happening in my car it was from the lack of compression or blow by pass the valves form the holes in my pistons.....it was very ugly.
I would check compression on the fron 3 cylinders and also check the condition of the plugs.......the plugs will tell you everything.
I hope it is not what my problem was!
Old Jul 25, 2003 | 07:19 PM
JAY25's Avatar
I have oil coming out of my crank case vent filter as well that makes two of us
Old Jul 26, 2003 | 04:56 AM
Bags's Avatar
170-175 PSI all around
What am I looking for on the plugs?
Oil?
NONE the last time I checked when I did my compression test.. 1 month ago
Old Jul 26, 2003 | 07:59 AM
LatinMax's Avatar
Oil?
Yes....oil.
and I would do the compression check again to see if there is any changes. If you have a wet plug (oil) then you might have a broken ring or piston or valve. The valve would be the least possible.
I had broken pistons that were blowing oil out of mine.
and I ended up with a new engine.
Old Jul 26, 2003 | 08:58 AM
xHypex's Avatar
From what I know you'll also get oil from the crankcase vent when pressures get very high and the oil blows by. That oil works its way back through the intake and ends up in your VI
-hype
Old Jul 26, 2003 | 12:32 PM
guestNX's Avatar
that is what catch cans are for, the little bit of oil and moisture in the blow-by gas.
if it is a lot of oil though, latinmax is right - that is not good, usually a sign of very bad news - but we are talking a good bit of oil. atleast from my experience it was a LOT of oil - covering everythign under that 1/2 of the hood haha
Old Jul 26, 2003 | 12:38 PM
guestNX's Avatar
Originally posted by slammed95
Solution: Bling-bling catch can.
Old Jul 27, 2003 | 05:05 AM
Bags's Avatar
Thanks HYPE.. I hear you LOUD and CLEAR
GuestNX.. the only thing with oil on it are 2 things driectly below the vent, but the re is oil under those 2 things from it running down but not to much.. I'll check my plugs after a few hard runs
Latinmax- i hope I do not have what you had
Old Jul 28, 2003 | 05:16 AM
ejj's Avatar
ejj
-hype
That's pretty much the purpose of the crankcase vent. Oil vapors get out through it, and back into the intake path (assuming you have it hooked back up to the intake).
Old Aug 15, 2003 | 05:18 PM
nismology's Avatar
What's the difference between the crankcase vent and the PCV valve??
Old Aug 18, 2003 | 10:01 AM
kingrukus's Avatar
no more maxima...
Yes what is the difference? The dealer just replaced my PCV valve claiming that it was the cause for my 1L of oil loss per 1000km problem. I personally think they are sh*tting me.
Old Aug 18, 2003 | 10:41 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
a crankcase vent/filter will be open all the time allowing oil vapor to pass through... and if I'm correct the PCV valve wil only open and allow oil vapor through into the intake tract under a certain amount of vaccum(not too sure on that, but it was worth a shot )
MaxLife17
Jun 27, 2019 01:37 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
