My ECU Changed Its Mind!! Help!
Yesterday at lunch, my Check Engine light came on. I performed the diagnostic to get the ECU code, and it reported "Engine Coolant Temperature Sensor." After work, I stopped at Auto Zone where I got the new sensor for $24.99. I went home, replaced the offending part, and reset the Check Engine light. All was good.
After driving for half an hour, the Check Engine light came on again. I again performed the diagnostic, and got codes for "EGR System Hi/Low Flow," "Knock Sensor," and "Rear Heated O2 Sensor."
Surely all three of these components cannot be defective, all of a sudden. What could I have done during the swap that is causing these ECU codes?!
Any help would be greatly appreciated.
Well i'm having the same damn problem with that code kinda. I got the code on my old engine, i changed the part and a week later the code came back (same code for me though) so i cleaned the connector with some wd40 and for like a month or 2 no codes...Then it came back so i just said screw it, not i've put a new engine in my car and got the same code yet again, i think its the wire harness connection thats actually the problem for some reason it gets so dirty which is odd cause its on top of the engine, maybe the fans blow crap into it i don't know really <shrug>
Mar 12, 2020 12:06 AM
03VQMAX
Nov 10, 2015 03:39 PM
220k+ A32
Sep 22, 2015 03:08 PM
QueensMAX
Sep 15, 2015 04:14 AM
lux97Max
Sep 11, 2015 01:12 PM
