Chirping/squeaking from front right
Hi all. I am a new owner of a 95 gxe 5spd and everytime I go over a bump with just the rightside tires, the right front corner makes an audible squeak - a high pitched chirping sound. Is anyone familiar with what might cause this? I know it's not the shock or spring itself, since I had the eibach kit with kyb's installed but the chirping was happening before (and still does). Maybe some part isn't greased up properly?
Also, it seems to rev a bit higher than I was expecting at ~120km/h (70mph) - roughly 3200rpm in 5th gear. Is this normal? I test drove 2 '95 gxe 5spd and both revved at 3200rpm. Figure this seemed high for a 3.0l engine but I guess the final drive ratio is set higher? My 2000 Altima I leased revved at 2700rpm in 5th at 120kph.
Thanks all for your time,
Bill.
Bill.
Squeak:
Sway bar bushings
Lower control arm bushings
Squirt some WD-40 one one component at a time, go for a ride and see if it stops it. As soon as you hit the right component with WD-40 your squeak will stop.
Sway bar bushings
Originally posted by njmaxseltd
Squeak:
Sway bar bushings
Squeak:
Sway bar bushings
I have something like 3100 rpm at 120km/h too and a 5 spd tranny. So you're ok.
Hdnseek
Sep 9, 2015 05:55 AM
