need help getting dash face plate off
ok this is dumb but im askin it any way im tring to get my stock bose head unit out but i can get the wood graine cover off that goes around it i have the tool to get under it but i dont know where the clips are and i didnt want to break it if some could help me out there that would be a plus
you have to remove the whole dash to get it out since its held in by screws on a bracket. you first need to remove the dash trim cover thats over your shifter and also take off the top air vents and you will see the screws to remove the dash
the shift cover pops up- you have to pull up from the bottom part first. the air vents also pop out and what I do is use a screwdriver to pry on the middle of the top of it and it should pop out. once you get those off then you can remove the ash tray and the only thing holding the dash is 4 screws- 2 on top and 2 on the bottom.
ok thanks alot for everbodys help i have been looking for a haynes manual for it i went to pepboys adavanced auto and they didnt have so i ordered off there site because i have a few manuals form them for other things i own well thanks agine u mad this job alto easier
actually now I remember you need to unscrew everything off the bracket meaning you need to take off the flip drawers, DINs, ect because the bracket is kinda made in a way that everything snaps on together even if there are no screws.
Yes, a stubbie with a fat end works best(not a pointy end) because it's short and your hand doesn't wobble at all when you turn it, unlike a longer screw driver there's more play and you tend to strip the philip head. Just apply a steady grip and push down hard as you turn it. Also a little WD 40 helps too, but use just a dab of it. You can spray it on a cotton swap and apply it on the screws.
worldwiderecognized
Sep 30, 2015 01:16 PM
