volumetric efficiency estimate
Old Aug 8, 2003 | 06:43 AM
Stephen Max's Avatar
How do you estimate the volumetric efficiency of a boosted car?
I have seen one approach where you just use the pressure ratio as the volumetric efficiency, which seems a bit optimistic.
Maybe a more realistic estimate is NA volumetric efficiency times pressure ratio?
Old Aug 8, 2003 | 06:55 AM
MardiGrasMax's Avatar
With boost I thought it was 100%
Old Aug 8, 2003 | 07:23 AM
I guess I'm thinking of an effective volumetric efficiency that includes the effect of the supercharger.
For instance, if you wanted to calculate air flow into the engine. I have seen an equation for a supercharged engine where the effective volumetric efficiency was just the pressure ratio produced by the blower. So for instance, if you are running 9 psi at 6500 rpm:
PR = (14.7 + 9)/14.7 = 1.61
so: cfm = (183 x 6500 x 1.61 x .5)/ 1728 = 554 cfm
where:
183 = engine displacement in cubic engines
6500 = engine rpm
.5 = number of intake strokes per engine revolution
1728 = conversion from cubic inches to cubic feet
But using the pressure ratio for the effective volumetric efficiency seems a tad optimistic to me.
Old Aug 11, 2003 | 07:11 AM
where:
6500 = engine rpm
Ooops. Silly me. I forgot to factor in the thermal efficiency of the blower. So if the blower is operating at about 65% efficiency, you get an estimated airflow of around 360 cfm.
Old Aug 12, 2003 | 06:15 AM
Confused's Avatar
Permanent Maxima.org Resident
since you are measuring the pressure ratio at the engine, wouldn't you ignore the blower efficiency?
Old Aug 12, 2003 | 06:40 AM
Hmmm. Good point. I think you're right.
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
