How important is O2 sensor?
Old Feb 7, 2001 | 08:49 PM
fred97gle's Avatar
I just installed the Apexi cat-back on my '97 and there was no hole for my O2 sensor behind the cat. I have it wired out of the way just above the pipe right now. No check engine light. I was wondering if I even need it. What exactly does it do and does it affect fuel/air mixture or the ECU? Anybody have some tech knowledge on this? Thanks.
Old Feb 7, 2001 | 09:02 PM
Daniel B. Martin's Avatar
The rear Oxygen Sensor monitors the performance of the main Catalytic Converter. It has no influence on the air/fuel ratio. However, I would have expected the Check Engine Light to go on. Don't be too surprised to see it go on in the next few days.
Old Feb 8, 2001 | 06:22 AM
madmax2k's Avatar
Yep....The Check Engine light should come on as part of the OBD II system.
Old Feb 8, 2001 | 11:58 AM
Weasel's Avatar
Is there a way to fool the car into thinking the O2 sensor is there and working?
Old Feb 8, 2001 | 12:22 PM
Yes, but...
[/I]
Yes, but not easily. There are Simulator Boxes which can be used to mimic sensor signals. These are useful diagnostic tools. I think they are expensive... don't know the price... don't have one.
A "savvy" electrical engineer could measure the signal coming from a healthy rear Oxygen Sensor and build a circuit which generates that signal. It is a sinusoidal waveform which varies between a low in the range of 0.0 - 0.3 vdc to a high in the range of 0.6 - 1.0 vdc. I don't know the frequency, but believe it to be low (10 hz or less).
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
