Help........driver's side axle coming out of tranny
My drivers side axle keeps coming out of tranny up to an inch.
This is the 2nd time in 3 weeks and i keep losing tranny fluid. Has this happened to anyone else??? What can I do to keep from having to push axle back in every 2 to 3 weeks??? Any help will be greatly appreciated!!!
Matt
This is the 2nd time in 3 weeks and i keep losing tranny fluid. Has this happened to anyone else??? What can I do to keep from having to push axle back in every 2 to 3 weeks??? Any help will be greatly appreciated!!!Matt
dude, before u do any damage, get your car towed to nearest shop that can take a look at it, or carefully drive to shop if its close enough...i never heard of that happening and i would be scared sh*tless of it just sliding off while driving...thats worst than a rim/tire falling off while driving
yeah, that's crazy **** man. when i had my eclipse gst i had curb checked and about a month later as i was driving my driveshaft popped out and all sorts of **** was falling out from under my car and it wouldn't move. had to tow it to dealership. turns out that curb check broke some midframe. that was scary enough, i would be terrified if my axle popped out on me.
Originally posted by Nismo
maybe the little retainer clip thats on the end of the shaft came off thats why its not snapping in
Or it may be weak. See if you can replace the retainer clip.
Originally posted by slammed95
I think he forgot to mention he has airbags.
IMO it's caused by the increased distance from the hub to the diff when the car is sitting on the ground. It's designed to slide a little to compensate for changes in distance with stock suspension travel.
Unless the distance is so great that the joints are at full length....
-Tony
Originally posted by araffio
Isn't that taken care of by the joints?
-Tony
-Tony
The CV joins will expand and contract quite a bit, there's plenty of room in there. Even fully jacked up pff the ground, your not pulling on your drive shafts so driving it on bags a little high should be irrelevent.
Lakersallday24
Jun 16, 2019 01:35 AM
vingodine
45
May 21, 2016 12:46 PM
kingw323
20
Oct 21, 2015 08:36 AM
Starrider
Sep 17, 2015 07:26 AM
