Springs and shocks?
Old Aug 16, 2003 | 10:24 AM
MaximaSnOOp's Avatar
Springs and shocks?
So i have a question about the two. Am i suppose to change those before i put a new set of rims on?
Old Aug 16, 2003 | 11:14 AM
maximaah's Avatar
They're really separate issues, except for the lowering part. Lots of folks change their suspension just to lower their car, as the wheel gap can be pretty distracting if you've got nice rims.
If you've got a few miles on your car or regularly travel rough roads, you may want to invest in new suspension components before you spend $$$ on rims. Throw in FSTB and maybe RSB while you're at it. It'll take about $1000 to do your suspension (give or take), depending on how much you do yourself, where you get the components, etc. The best place for KYB stuff that I've seen is www.taylorautomotive.com.
There's a long, usually incomplete list of suspension components that you need, but here's what I've put together, seems to be the classic set-up:
KYB GR2 struts (front) and shocks (rear), alt: KYB AGX (adjustable)
Springs: Progress, H&R, MaxSpeed
KYB dust boots (front: SB103, rear: SB108)
KYB top mounts (or Motivational in rear if you want more travel)
Nissan OEM "spring seats": Front p/n 54034-85E10, Rear p/n 55031-33P10
Radio Shack spiral wire wrap to reduce noise due to springs
This will drop about 1.5" front, 1.3" rear.
FSTB from eBay (cheap) or custommaxima.com (looks)
RSB from cusommaxima.com (Progress) or cattman.com (Addco)
Steve
Old Aug 16, 2003 | 07:45 PM
Jatan's Avatar
KYB dustboots come with bumpstops. Just did my GR-2/MaxSpeed suspension today. Replaced the dustboots, strut bearings, upper strut mounts, and I used vinyl tubing as a wrap for the springs
Rides great! And the squeaking from the old rusted springs is gone
Old Aug 16, 2003 | 07:55 PM
maximaah's Avatar
Crap! Anyone need some OEM bumpstops?
Old Aug 16, 2003 | 09:36 PM
DR0832's Avatar
JaTaN what size wheels/tires are you riding on?
Old Aug 17, 2003 | 05:49 AM
Jatan's Avatar
Stock 15" Honeycombs with the tires in my sig
Old Aug 17, 2003 | 08:49 AM
nismos14's Avatar
§è~® f®ÈÄk
my suspension only cost me $200 :-D got used h & r's $100, install $100 from tom, free tok blues from my bro free rear dustboots from bro, fronts from tom! woo hoo I LOVE IT
Old Aug 17, 2003 | 10:16 AM
maximaah's Avatar
Aw, shaddup.
Old Aug 17, 2003 | 10:44 PM
ThurzNite's Avatar
rims first. they make a bigger diff in handling. actually, if you're really on a budget and want bang for buck, just get top notch tires.
Jae
Old Aug 18, 2003 | 07:46 AM
BOZOnPJs's Avatar
Tom, got any other parts you wanna give away?..like agx or illuminas
Old Aug 20, 2003 | 08:20 PM
maximaah's Avatar
OK, what I actually ordered from Courtesy was not bumpstops, but a rubber "isolation" ring that sits between the spring "perch" on the struts/shocks and the springs, and isolates noise from the springs.
I haven't heard of anyone else ordering these things, hope it helps.
Also, I wrapped my Progress springs with the Radio Shack stuff but would like to know if you guys think this is wrapped enough or whether I will need to cover a few more coils before the install:
Old Aug 20, 2003 | 08:23 PM
maximaah's Avatar
Running the same tires but on steel rims.
Old Aug 21, 2003 | 05:28 AM
Jatan's Avatar
That's how I wrapped them, but I used vinyl tubing
I need to get bigger rims
Old Aug 21, 2003 | 07:17 PM
maximaah's Avatar
Nissan OEM "bump stops": Front p/n 54034-85E10, Rear p/n 55031-33P10
OK, so here's the last piece. I actually didn't buy "bump stops" from Courtesy, they're called "spring seats" and don't do anything more than wrap the lowest coil of the spring. Bought 'em anyway just so I don't have problems in the future.
Old Aug 22, 2003 | 10:21 PM
Taken2DaMax's Avatar
maximaah how much did you get those from the $tealer, i meant dealer?
Old Aug 25, 2003 | 04:35 AM
maximaah's Avatar
$35 shipped.
Old Aug 25, 2003 | 12:02 PM
DoGGy
why do u wrap em ?
Old Aug 25, 2003 | 12:19 PM
Jatan's Avatar
Originally posted by DoGGy
why do u wrap em ?
So they don't rub against each other and so they don't make the annoying sound
It's cheaper than buying the isolators that are around $10 each.
Old Aug 25, 2003 | 01:33 PM
maximaah's Avatar
Except when you buy both...
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
