battery and brake light on
your alternator is DEAD, replace ASAP, your car is running off the batery. go to autozone and get an alternator. it cost me 200 after the core. you get a lifetime warrenty on it too.
how to is here http://www.motorvate.ca/mvp.php
would that make the brake light come on also?its not just the battery light ,the brake light is on also?
Originally posted by pocketrocket
That is the setup. A diode in your meter cluster ties the brake and battery/charge lamp come on together whenever the charge lamp is trigerred.
so does this mean its definitely the altenator?
It means that the alternator is triggering the lamp, so most likely yes.
Take it to Autozone, etc for a quick & free test. I'd do it soon. You could only last a few hours off the battery, not very long if you run your A/C, system, headlights, etc.
Its the alternator, mine flickered on and of for both lights. Then it stayed on steady. Then the car died 4 hours later. SUCKS to be stuck in RI when im from brooklyn. Got my shop to replace it with a HIGH OUTPUT for $180.
It's your alternator. Find someone with a Passport 8500 radar detector and have them put it on the voltage meter function. Most likely it will read far below the normal 13-13.5V. I knew my alternator was bad because my Passport was reading under 11 volts.
Originally posted by 95emeraldgxe
better do the swap quick, i got stranded like a few feet before the highway entrance at avis rent a car, my lights were on for about 3 days before the battery went dead
i hear what u guys are saying about the altenator but i took it to autozone and the only thing that came up wrong was the altenator
think of an altenator as your cell phone charger.. if leave your charger at your mother-in-law's house .. you have x amount of time before you can't use the phone anymore. When the cell phone battery does die, its not the battery is bad, it just needs to be charged. So yes the altenator is the only thing thats bad.. because its not charging the battery.
Originally posted by SprintMax
thats because the altenator charges the battery..
i owe u all an apology it WAS the altenator in the shop as we speak costing me a hefty 488 dollars but everybody on here was right thanks
tsi6001
Oct 3, 2022 10:23 PM
JMag90
Aug 25, 2015 09:17 AM
