too much motor oil?
too much motor oil?
Hey I changed my motor oil this weekend and it was on a little hill downwards so i dont think i got all of the oil out. I put in 4.25 quarts. But when I measure with the dip stick the reading is like off the charts. What happens if there is too much oil?
Re: too much motor oil?
The dipstick's not very accurate on mine; it shows WAY off the scale even after draining it all (forward uphill, filter change) and putting 4.25qts in there...
I'm considering going to the dealer about it after I do the next oil change, so I can tell them with an absolute straight face that I know exactly how much oil is in there...
thank you guyz
Well I actually parked downhill on my drivway and jacked up the front to try and make it striaght but at the 4th level of the jack i was too scared to go anymore. Not that big of deal ill just drain it and get another bottle of mobil 1
BTW: I installed one of those Fram Sure Drain oil drain plugs and the thing works great!!! I highly recommend it for us people who do our own oil changes.
FRAM® SureDRAIN™ Fast Access Oil Change System
The easier way to change your oil. Now you can drain your oil with no tools, no mess and no hot oil on your hands with the revolutionary new SureDRAIN Fast Access Oil Change System brought to you by the trusted name in filters….FRAM.
Now you can have instant access to your oil with just a turn of the wrist!
Proprietary SureDRAIN Valve - this unique, heavy duty Actuator Valve is precision engineered to permanently replace your existing oil drain plug and allow instant oil access and draining.
Twist on Drain Hose - Designed for fast, easy, twist on operation, the heavy duty FRAM drain hose starts the flow of oil directly into your receptacle with the turn of your wrist.
Added Protection Dust Cover - To keep the SureDRAIN valve free from road dirt and safe from undercarriage debris, the ultra-rugged SureDRAIN dust cover locks firmly into place until the next oil change. Like all SureDRAIN parts, this dust cover has been tested against leaks, corrosion, vibration and road damage.
I know this sounds stupid, but are you reading the back side of the dipstick? The side with the hatching on it? I get the same off-the-chart reading on the frontside, but the backsides usally a good 1/2 inch below that. Peace_
I'll take another look next time I get gas just to be sure, though...
When you refill the oil goes right past the dip stick, its that way on the 3.0 VQ also. If you let it sit for a 1/2hr or more with the stick 1/2 way, or all the way, out then take your reading you'll be much more accurate.
If your wooried about to much oil and don't have a SureDrain then just put a new oil filter on. If it's a high dollar filter put it in the box upside down and use it on your next change.
Originally Posted by NizanDrivn
I wasa under the impression that excess oil gets burn up/blown out
Way overfill it and the crank will slap the free surface of the oil and turn it into foam (read: build pressure in the crankcase, which isn't too good for the crank oil seals).
Norm
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
