ignition retard under boost
Old Sep 2, 2003 | 06:00 AM
guestNX's Avatar
Is it possible to for us to use a MSD 6 BTM?
" The Universal Boost Timing Master allows you to adjust the ignition timing in relation to the boost pressure plus it has a built-in inductive ignition. You can adjust the dash mounted control **** to retard the timing 1° - 3° per pound of boost, up to 20°. "
the real question is, will this work with our coil ignition:
"The Universal BTM is designed to work with most single coil factory or aftermarket ignition amplifiers and points type distributors."
Link to MSD 6 BTM product page
MSD-5462 $165 from summit
Old Sep 2, 2003 | 06:02 AM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
I SERIOUSLY don't see it working on a DIS ignition...but can't you guys use J&S?? doesn't J&S retard under boost or is it just set value?
Old Sep 2, 2003 | 06:18 AM
guestNX's Avatar
yes but look at the price difference. 165 vs ~500-700 for J&S. J&S in my opin. is a great unit, and better than this MSD BTM , but enough to justify 500$ more expense if the MSD would work? not for me.
Old Sep 2, 2003 | 06:25 AM
DA-MAX's Avatar
true...but the key phrase is "if the MSD would work?" one of yall should try it out..~$80 off Ebay if you're lucky(thats how I got mine for my Integra) good luck with the wiring though...
Old Sep 2, 2003 | 07:26 AM
sx7r's Avatar
j&s is more expensive, but in addition to boost referenced timing retard, it also retards timing for individual cylinders based on knock - which can save your motor. furturemore, if needed, it can shut off nitrous solenoids when detonation is detected.
Old Sep 3, 2003 | 03:32 AM
John at J&S's Avatar
MSD6's won't work, for a couple reasons. First, it's designed to work with one coil, because it's a one channel unit. You would need three of them. Then you will need to change out all the coils, since the MSD can't drive the stock ones. The MSD needs access to both the coil positive and the coil negative. Your coils have a built in ignition transistor, which is connected internally to the coil negative, so you can't get to it.
You could change out all the coils, and use an MSD DIS4. Use three of the four channels, and wire the car for waste spark.
Oh, you are gonna also have check engine lights.
The J&S controls the stock coils, and we have the check engine light problem solved.
The unit does not control the nitrous solenoid. We sense when the solenoid turns on, and add a selectable amount of nitrous retard.
We have a new, lower cost retard display.
Old Sep 3, 2003 | 04:10 AM
Drew96I30's Avatar
Hey Guest NX, I have a used J&S for sale if you're interested.
Old Sep 3, 2003 | 05:54 AM
Stephen Max's Avatar
Que mucho?
Old Sep 3, 2003 | 07:31 AM
guestNX's Avatar
wow this man knows his stuff thank you for all the info!
drew96: check your pm's
Old Sep 3, 2003 | 08:18 AM
Chunger's Avatar
My other car is a Hybrid
Hi John! The UltraSafeguard is still working great! You make an awesome product! I may call you regarding the "retard only" monitor...
Old Sep 3, 2003 | 05:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Nice!
John if you don't mind....can you explain WHY you guys require the ignition changed to 'wasted spark'. I've read the instructions and everything looks pretty simple(haven't installed yet!), but I was curious why you guys did that.
Any negative to a 'waste spark' setup?
Old Sep 3, 2003 | 08:02 PM
Waste spark on a six cylinder only requires three channels. There just wasn't enough room on the circuit board for six channels. All I could squeeze in was four.
The AEM standalone has five ignition channels, so it also requires waste spark operation on a six cylinder.
Photos here:
http://www.jandssafeguard.com/images/4ChProto.jpg
http://www.jandssafeguard.com/images/4coil.jpg
Old Sep 3, 2003 | 11:00 PM
IceY2K1's Avatar
Thanks John...VERY impressive looking product
Plus, you can't go wrong with something that comes in a Crown Royal velour bag, eh?
Just wondering, can using the wasted spark ignition pattern cause the coils to NOT have enough time to charge between discharges at high RPM?
Photos here:
Old Sep 4, 2003 | 04:07 AM
At 7500 RPM, a six cylinder ignition with a single coil and a distributor will fire a plug once every 2.666 msec. A three channel waste spark system has three times as much time for each coil, so it's not a problem.
Old Sep 4, 2003 | 08:42 AM
delio's Avatar
Guest I have a brand new never installed J&S for sale if your interested. PM me.
Old Sep 6, 2003 | 07:11 AM
MardiGrasMax's Avatar
The J&S Ultra Safeguard is what made my 11.9et a reality. It would not have happend with out it! Super product, super customer support, highly recomended!!!
Old Sep 6, 2003 | 07:29 AM
hlh0501's Avatar
with a consultII or whatever at the nissan dealers to adjust ecu's... can I advance my timing across the board and save/burn it like that? then, add the J&S - to get basically the same effect as your ecu+J&S combo?
Old Sep 6, 2003 | 08:42 AM
At what level of boost in a supercharged, non-intercooled car would you consider the Ultra Safeguard an absolute necessity?
Also, do the timing changes and afr that JWT programs into an ecu in their turbo program make an Ultra Safeguard unneccessary, or at least raise the boost level for safe operation without it?
Old Sep 6, 2003 | 04:05 PM
I didnt think the dealer could do this on a 4th gen ECU, but if so , yes it would have the same effect.
Old Sep 6, 2003 | 04:15 PM
Hard to say what level, but I'd say 11psi+ and also depends on your tuning and climate.
A JWT ECU is supposed to be plug and play up to the max of your injectors (620whp for 555cc). However I plan on keeping my J&S as a "Safeguard" Also I can run a large wet nitrous shot and use the Safeguard to pull timing for that aside from waht the JWT ECU is doing.
JWT does offer a 100oct racing gas turbo program, I am considering getting that and using the J&S to pull timing for the street, then at the track run the 100oct with the J&S boost timing retard turned off. They also have a studder program add on for building boost for launch and a program for water/alch injection. All these add ons get expensive though.
JWT is tuned conservativly, you wont get every last HP out of their normal turbo program, but for those who want a simple way to plug and play its purty good.
I just dig the 7200rpm limit and abality to run 555cc injectors at stock fuel pressure.
Also remember this, the Max ignores the knock sensor at WOT, so the JWT ECU can not do what the J&S does. If you get a bad tank of gas with a JWT ECU and run 12psi, you probabbly toast. With a J&S Safeguard your "SAFE"!!!, but boy will the knock monitor light up real pretty like as its saving your a s s!
Old Sep 6, 2003 | 08:13 PM
Drew96I30's Avatar
anyone wanna buy my J&S? Its like brand new, I'm open to offers. PM or email me with offers.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
AaronL
Aug 8, 2020 10:31 AM
MichMaxFan
Sep 30, 2015 09:18 AM
